Flush Anti-Freeze |
Taya
Newbie Joined: 25 Oct 2010 Location: York Ontario Online Status: Offline Posts: 6 |
Topic: Flush Anti-Freeze Posted: 26 Jul 2011 at 11:53am |
This is my first spring with my R-Pod and I have to flush the anti-freeze out of the system. No idea how to do that safely in a neighborhood full of dogs. Any suggestions?
Taya H.
Taya
Posted: 26 Jul 2011 at 12:26pm |
OK that was a really dumb question. I realize now it goes into my grey water tank and I have to dump it at a dumping station... duh!
Taya H.
kymooses
Posted: 26 Jul 2011 at 1:28pm |
If it was done with proper RV antifreeze and hopefully it was then you have no worries to begin with as the RV type of antifreeze is non-toxic.
Propylene glycol, the primary ingredient in RV anti-freeze, is a common food additive that is also used in many other products such as cosmetics. It's both biodegradable and water soluble, and requires no special handling in normal consumer quantities.
Posted: 26 Jul 2011 at 3:48pm |
Some of it will end up in your gray tank some in the black tank. Don't forget to take the caps off the low-point drains outside for a second or two.
