  New Posts New Posts RSS Feed: adding another brake light - help
Topic Closedadding another brake light - help
Direct Link To This Post Topic: adding another brake light - help
    Posted: 27 Oct 2011 at 10:37am
Even if we get the retrofit it will not include a 3rd brake light, but it would provide a good location to mount one (just below the new "fin"). I like the idea, nobody behind the car behind you can see the brake lights in its current configuration. Fishing through the wall would be difficult since they have it filled with insulation. From what I've read the retrofit used in Canada does what you describe, Gretchen, and runs the wire over to the rubber cover and then under it. If I have to do the retrofit myself I will probably put running (and now a 3rd brake) lights up on the A/C cover so I can get more visibility and hide the wires better.
TerryM View Drop Down
Direct Link To This Post Posted: 27 Oct 2011 at 4:18am
The Canadian Government forced a recall for lights on the fenders and the marker lights up high on the back.  Forest River is asking for a waiver on the ones here without the lights.  They say it will cost too much to retrofit them.  If that happens I guess we are on our own to make our campers legal.
Here is a link to the discussion about it:
http://rpod-owners.com/forum_posts.asp?TID=2104&title=us-rpod-owners-20092010-models-please-read
Terry
dsmiths View Drop Down
Direct Link To This Post Posted: 26 Oct 2011 at 10:52pm
Terry is the NTSB involved ? if so we may be getting a freebie, I think it would be a nice feature for safety, and am I correct in my reading that the Canadian Gov requires it on R Pods ?
Dane and Donna Smith
2011 RP-172
lift kit
Direct Link To This Post Posted: 26 Oct 2011 at 10:35pm
I think you should hold off on doing that until a decision is made by the National Transportation folks about a recall on our back lights.
Terry
Direct Link To This Post Posted: 26 Oct 2011 at 9:45pm
I read that in Canada they require the light in the upper back of the pod, I wonder if you could contact a Canadian Forest River dealer and see if there is a kit/instructions on how to, good luck, let us know what you find.
2011 RP-172
lift kit
Gretchen View Drop Down
Direct Link To This Post Posted: 26 Oct 2011 at 8:54pm
Just wondering if anyone has installed an additional brake light say above the back window.  I bought a nice LED strip and am trying to figure out the best way to tie it in with as few holes as possible. I got some skinny wire track that adheres with double sided tape if I don't want to go thru as not sure if I could fish a wire down thru the wall.
HAS ANYONE EVER FISHED  A WIRE THRU THE OUTSIDE WALL?  How did you do it?
Or was thinking could use a couple feet of track to bring wire to side and tuck it in the seam cover which you can pinch open/closed, but than I still have to make a hole in it.
Any help is appreciated. THanks.Confused
Gretchen in Tennessee; Excited new R-Pod 151 owner and quilter
He has set eternity in the hearts of men; yet they cannot fathom what God has done from beginning to end. Ecc 3:11b
