Interstate battery replacement |
Post Reply | Page 12> |
dsmiths
Senior Member Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
Topic: Interstate battery replacement Posted: 08 Jan 2012 at 7:36pm |
Gotcha , will do in the future so maybe helps others.
Dane and Donna Smith
Posted: 08 Jan 2012 at 6:52pm |
blissful, I'm guessing you didn't see the email I sent you, you must be subscribed to this thread - and you are replying to the notifications every time someone posts here. Your replies to those emails are only coming to me, they aren't showing up on the board. When you get the emails you need to come back to the board to reply.
dsmiths
Posted: 08 Jan 2012 at 2:21pm |
oops sorry about the typo, the multi vibrator circuit changes dc to ac, then its increased in voltage and rectified back to dc.
dsmiths
Posted: 08 Jan 2012 at 2:20pm |
David, good idea on coating the terminals, the charger may get its QRM from multi vibrator circuit changing ac to ac, being a ham you understand. I think you have a great idea, put in the second battery put it in paralel with the main and that would be ok, but I think they make an isolator (maybe a hi capacity diode) that will let battery number 2 charge, but not let it drain back into the main battery or associated circuits when not charging, this keeps battery number 2 fully charged but will not let it run down in off charging conditions. Thanks for your great tips. Dane
Guests
Guest Group |
Posted: 08 Jan 2012 at 12:03pm |
That is what I do - on the camper. I give both positive and negative leads a light coat of dielectric grease, put them in individual sandwich bags and then wrap both (individually) in black electrical tape. Then I tuck everything up underneath the camper to keep it out of the direct weather. If I would plug into commercial power, everything is OK and nothing should short out.
I've read on another RV forum (RV net???) some other hams discussing the QRM (noise) so, it must not be uncommon with this unit. In fairness to WFCO, they probably didn't design the unit to be a "communications grade" power supply (I don't know why they would). One fellow actually changed out his unit for another brand and it helped.........but that's not inexpensive. Me, if it gets to be annoying, I just unplug from commercial power and run off of the batteries. I really only need commercial power for the air conditioner (don't use the microwave and can run the water heater on propane). Other than that, the WFCO seems to do just fine. Given your background, maybe you can answer this for me: My TV is an 09 Silverado with the tow package, which included a second battery tray. I was thinking, rather than lug around the generator, run the camper on one battery and put the second battery in the truck, which could be charged up when just driving around sightseeing, etc. When the camper battery gets low, just swap the two. Is there anything "special" about hooking up the second battery? And, do I want to throw my back out lifting a generator or would I rather throw my back out lifting batteries??? PS - This method would also get some weight off of the trailer tongue....I'm getting close to the maximum that I should put there without a weight distribution hitch.
dsmiths
Posted: 08 Jan 2012 at 10:38am |
David, thanks for the reply, I do understand QRM. I may remove the battery and take it in the man cave on a float charger. and I would think it wise to insulate the positive battery terminal, I assume if it touches ground it may damage to charger portion of the power panel.
Guests
Guest Group |
Posted: 08 Jan 2012 at 5:10am |
Most everything I have read about the WFCO indicates it is a fine unit and I have had good luck with all of mine. There is only one exception...it is a bit "RF noisy" for those of us who are Ham radio operators. CB enthusiast would likely encounter the same issue. I bring mine in the garage during the winter months, mainly for my convenience. Though this winter has been mild so far, I really don't want to go outside and check things on the camper (like the water level in the cells) when the temps are zero and below.
dsmiths
Posted: 07 Jan 2012 at 6:20pm |
I put my charger on the battery and it is fully charged, does the pod electrical panel include an internal battery charger ? My pod is covered and winterized next to my outbuilding, but I have it plugged in so that sometimes when I go down there and hide I have power. I need to get my manual out and read up on it.
dsmiths
Posted: 06 Jan 2012 at 7:47pm |
At my A C Delco tech shop we carry Interstate batteries and they have always bent over backwards for me during a Warranty situation. I understand the battery is installed by the selling dealer and not F R. I state batteries are not cheap, but really high quality, they do fail sometimes like anything else mechanical. I plan on upgrading mine this coming spring, my battery was new 10/2011, but it is a low capacity battery. on the good note, I get them at cost. Opps I have not put my charger on, I better do that tomorrow. I know better.
Posted: 06 Jan 2012 at 6:23pm |
I have never had problems on a camper, but have replaced Interstate batteries a few times on vehicles. Always been a breeze. Sorry to hear of your problem. I guess I would not do lots of business with that dealer if they can't handle this.
