  New Posts New Posts RSS Feed: Finally!!
Topic ClosedFinally!!
kymooses View Drop Down
Direct Link To This Post Topic: Finally!!
    Posted: 12 May 2012 at 4:04pm
Good report so far!
Only thing I know to metion with your battery not charging while towing is that depending on if tow package was standard or not sometimes an additional wire must be run from the TV battery back to where your Pod connects for charging.
Other than that, have fun in the shower, you'll get used to it.
Oh and very jealous of the fresh local cheap seafood dinners!!
Podsible Dream View Drop Down
Direct Link To This Post Posted: 12 May 2012 at 6:40pm
I think I went through and fixed almost all the hinge screws in our cabinet doors. A drop of glue and a penny match stick broken off in the hole, and put the screw back in. The screws in the Pod are all with a square drive head, so one of those driver bits needs to be in the tool box.
Happy podding!
Chris and Walt
'10 RP-171 'Free Spirit'
Goose View Drop Down
Direct Link To This Post Posted: 12 May 2012 at 9:53pm
   Glade that you are having a great time.    Goose
Direct Link To This Post Posted: 13 May 2012 at 4:12pm
Yep, check to see if your tow vehicle needs a relay or fuse, ours needed both, they came in a bag with the cable dongle to hook up the brake controller.
