Water heater element |
Post Reply | Page 123> |
Gerald
Groupie Joined: 27 May 2010 Location: Bowmanville, On Online Status: Offline Posts: 73 |
Topic: Water heater element Posted: 25 May 2012 at 1:14pm |
Fried my electric water heater element on our first trip this year. Stupid me forgot to fill the hot water tank before flipping on the electric switch on the heater. Has anyone replaced the element themselves?
2010 R-Pod 177 / 2009 GMC Canyon 4X4
Gerald, Lydia and The Boys (2 Shelties)......Canuck Podders |
Posted: 25 May 2012 at 4:40pm |
Happens..
This is without having done it before: just a WAG.. Should be no big deal, looks like you disconnect from shore power, throw breaker, remove the black cover right next to the switch, disconnect wires, unscrew the element, screw in the new, hook up wires, replace cover, fill with water, reset breaker, reconnect shore power, heat. Don't forget a little teflon tape on the threads. OR maybe not.. it appears on some RV water heaters the element is in the BACK of the unit.. Now I gotta go look.. EDIT:.. works just like I thought. ASSUMING you have the same suburban SW6DE I have.. the part number appears to be: 232767 The manual: http://manuals.adventurerv.net/SW6D-SW6DE-SW6DM-SW6DEM-Installation.pdf Did you try the "reset" buttons..? |
greynomad
Newbie Joined: 20 May 2012 Online Status: Offline Posts: 22 |
Posted: 27 May 2012 at 10:01am |
I believe I am right behind you on the fried elements for the hot water system.
When I picked up the RPOD I had so much information thrown at me in a very short period of time I missed getting more details on the hot water system. Not a great way to learn the system......... |
Keith-N-Dar
Posted: 27 May 2012 at 9:25pm |
Do all the pods have an electric element? I have never found a switch in the water heater bay. Do we have a picture posted somewhere here that shows where it is>
Keith-N-Dar
Posted: 27 May 2012 at 9:32pm |
Just make sure at the beginning of the season that you hook up your hose at home, and leave one of the hot water valves open until the air stops sputtering out. Then you can leave it filled until you winterize in the fall.
Posted: 27 May 2012 at 10:17pm |
AFTER you set the 3 valves to non-bypass... else.. well... you know..
Posted: 27 May 2012 at 10:18pm |
Yes, I believe this to be true. The brocure said they all had 2 way water heaters..
ToddsPod
Groupie Joined: 20 May 2010 Location: Conroe, Texas Online Status: Offline Posts: 77 |
Posted: 27 May 2012 at 10:46pm |
'07 Dodge RAM 1500 ST Longbed QuadCab 4.7L V8 --- '10 Forest River R-Pod 172 |
Keith-N-Dar
Posted: 28 May 2012 at 7:34am |
Thanks. I will look again today.
Keith-N-Dar
Keith-N-Dar
Posted: 28 May 2012 at 12:22pm |
Found it!
Keith-N-Dar
