Originally posted by greynomad
Had the electronic brake system incorporated with my Toyota tow system. Brakes had been working fine until this morning. Had spent the night at a RV sight with everything hooked up for a early morning get away. Down the freeway it was for 14 hrs and the brakes got worst by the mile. If I hit the brakes with any pressure the POD would wag the back end of the truck like a dog. At times when coming to a stop the right POD tyre would lock up. What could have happen overnight to the system? It was a bloody nightmare going thru towns with stop lights |
There is an adjustment for how much braking goes into the trailer. On my Ram, which is digital, there is a "+"-button and a "-"-button for whether I want more, or less, braking to the trailer. On my Dakota it is a thumbwheel on the side of the brake controller. You need to figure out how to set that on the Toyota. When you find out how it is done lower the braking.
I try to adjust mine so that the trailer stops right with the truck. If it feels like the trailer is pushing the TV when I stop then I increase the braking a little bit. If it feels like the trailer is stopping the TV then I decrease the brake.
If it is like my Dakota it is easy to inadvertently "adjust" the brake. Anyway, that's the most likely scenario.
Good luck.
