Sewage smell.. propane leak? |
Post Reply | Page 12> |
plains
Newbie Joined: 09 Jul 2012 Online Status: Offline Posts: 25 |
Topic: Sewage smell.. propane leak? Posted: 10 Aug 2012 at 2:27am |
Tonight my wife and I took our Pod to the dump station to finally thoroughly clean the black water tank with our newly purchased Camco Duel Flush Pro. We bought our 2010 R-Pod used a few months ago and the black water sensors have never been right. After about an hour of flushing, it seemed we finally had things cleaned. I guess the previous owner didn't pay much attention to his tank maintenance - wow.
Upon stopping at the dump station, we smelled a terribly strong odor outside. I didn't think much of it as it's a hot day in the summer and dump stations never smell good. When we entered the Pod, we were greeted with an even stronger odor. Upon returning home, the smell lingered inside and out. We ran the fan for an hour with all windows open, sprayed air freshener, added tank chemicals and deodorizer, and could not get rid of the smell. I noticed that it was very strong in the kitchen area of the Pod, but could not for life of me figure out why I could smell it outside as well as inside. Finally, a few minutes ago, I followed my nose more closely and it seems the smell is coming from our furnace by the bed. We haven't run it more than once or twice to test it out, and it hasn't been turned on in about a month. It smells strongly of sewage/rotten eggs/dead animals, and from what I know, that is what LP Gas smells like. I turned off the LP tank immediately, but our LP leak detector never sounded, and we had candles burning inside the Pod this evening, and we're still alive? Is it possible we have a small leak? Has anyone experienced a similar smell?
plains
Posted: 10 Aug 2012 at 2:32am |
Just a small follow up-- the smell is definitely NOT coming from our black water hose, hose holder, black or grey water dump valves, kitchen sink, or toilet. It seems to be strongest right around the refrigerator and especially strong at the furnace.
Posted: 10 Aug 2012 at 9:17am |
Before you do anything make sure the battery is disconnected and the pod isn't plugged into your house to eliminate any sources of a spark.
The smell should go away quickly once the tank is off and the supply line has lost pressure - assuming it is a LPG leak. If the smell is still there today it isn't LPG. This is probably true since you had lit candles in there and didn't go boom!
Do you have any portable LPG appliances like a small lantern? You could put that right up to your LP detector and turn it on (unlit) to see if it detects the gas. It should happen quickly, I've triggered ours by leaving the toilet valve open while adding water to the black tank after dumping it.
plains
Posted: 10 Aug 2012 at 9:41am |
Nope, no other LPG appliances. The gas has been off overnight, and the smell still lingers at the furnace. I am seriously wondering if an animal has somehow died in there. There's nothing visible from the back access panel, but I plan to remove the front and possibly the entire unit if need be. Perhaps if one did die in there, when we drove the Pod, it may have "aired" the stench out for us to smell. Seems far fetched to me, and I really don't know how anything could crawl in there, but I am running low on ideas.
Posted: 10 Aug 2012 at 10:26am |
A dead mouse is possible, the bottom of the pods aren't sealed well. By now it wouldn't be LPG. |
dsmiths
Posted: 10 Aug 2012 at 12:12pm |
I bet you have a snake that has crawled up the vent for the furnace, they love getting into tight dark spaces hunting for mice, good luck on finding mr stinky.
Dane and Donna Smith
plains
Posted: 11 Aug 2012 at 12:24pm |
No signs of a snake or any other animal. No leaks in the plumbing under the shower or toilet. No signs of any leaks under the Pod or any holes in the tanks. Also certain it's not a propane leak as I turned that off for 12 hours and the smell lingered.
I cleaned out the p-trap below the shower, although it was hardly dirty at all. I also climbed on top and cleaned out our Cyclone sewer vent. Taking it off and looking down the pipe, I didn't see any clogs. I sprayed the hose down it a little to make sure, and water seemed to have no problem draining into the tanks, so I know air should be able to pass through as well. My only thought is that we are still dealing with "stuff" in our black water tank from the previous owner. Maybe its compacted enough that even blasting it with our tank cleaner didn't help. Who knows, but I'm getting some water softener today, and I'm hopping that next time I dump things will improve. I still can't figure out why the smell is so prevalent around the furnace/under the shower. It also doesn't make sense that I can smell it outside, especially under the Pod.
ToddsPod
Groupie Joined: 20 May 2010 Location: Conroe, Texas Online Status: Offline Posts: 77 |
Posted: 11 Aug 2012 at 12:54pm |
Have you tried pulling out the mattress? I imagine they could get pretty funky. Also, for the black tank, I've hear you can dump 10-20 lbs of ice in there before travelling to scrub things off the sides and bottom and such, then it melts and you dump it along with whatever else is in there after it melts. I imagine that is similar to what you plan on using the water softener for. Am I correct? |
'07 Dodge RAM 1500 ST Longbed QuadCab 4.7L V8 --- '10 Forest River R-Pod 172 |
Bill-GA
Senior Member Joined: 13 Jan 2012 Location: Cumming, GA Online Status: Offline Posts: 214 |
Posted: 11 Aug 2012 at 2:22pm |
Have you checked the toilet? I took mine off to replace the rear flush
value and there is a rubber/foam "washer" between the toilet (pipe) and the floor - this is a vapor seal from toilet to tank ... Only costs a few dollars. I would try to gently rock toilet side-to-side to see if it loose. If loose, tighten bolts on sides of toilet. If not, it might be worth while taking toilet out to check foam washer. Hint: tighten and remove water line in rear of toilet when toilet bolts are off for better access to value fitting.
Bill & Bev
13 yr old dachshund 'Elsa' 2010 RP-176T (tent & slide-out) 2011 Toyota Tundra 2WD TV |
plains
Posted: 12 Aug 2012 at 5:55pm |
As far the inside goes:
Our mattress is brand new. We ripped out the futon and installed a real bed first thing after buying our Pod. It doesn't smell around the toilet in the bathroom, and the toilet doesn't appear to be loose. There are no signs of moisture around any of the connections on the pipe going from the toilet to the black water tank, and the pipe doesn't seem to be the source of the odor. The hot water heater smells the strongest of anything, but our hot water doesn't stink, and I'm guessing that the styrofoam insulation around it is simply absorbing the smell better than anything else. As far as outside goes: It smells strongest around the driver side tire, in-between the black water dump valve and the wheel well. It's not the actual valve, as that doesn't have any kind of odor, and I don't see any obvious leaks or signs of trouble around the black water tank on that side. I'm stumped. Thinking I might have to take it to a repair center. Last time I called they were booked 2 months out. All this for a phantom smell.
