  New Posts New Posts RSS Feed: Fresh water system question
Topic ClosedFresh water system question
NS Podder View Drop Down
Direct Link To This Post Topic: Fresh water system question
    Posted: 06 Sep 2012 at 10:36am
Thank you all for the advise. I'll leave it turned off during this weekend's trip. Lots to learn compared to a tent. Loving every minute of it though. Smile
2013 rpod 177
2008 Mitsubishi Outlander XLS
danthoman View Drop Down
Direct Link To This Post Posted: 06 Sep 2012 at 9:55am
Just to throw some fuel to the fire; my dealer said that that the pump could be damaged if you used it while connected to city water.  He reiterated the point several times during the demo.  However the one way valves illustrated in bhamster post should eliminate that problem.
Direct Link To This Post Posted: 05 Sep 2012 at 9:40pm
No worries on running the pump dry, they are designed for it.
dsmiths View Drop Down
Direct Link To This Post Posted: 05 Sep 2012 at 8:46pm
good diagram
Dane and Donna Smith
2011 RP-172
lift kit
bhamster View Drop Down
Direct Link To This Post Posted: 05 Sep 2012 at 8:42pm
Having a 2 year old daughter that loves to flip all the switches in the trailer, I can confirm that the pump will run with a city water connection. When the faucet is open the pressure in the line drops to below the cut-in pressure for the pump. But they will work together (or fight depending on how you think about it) so that the amount of water drawn from the fresh tank is less. But as the other replies mentioned, just leave it off if you're connected to city water. The pressure in the city line eliminates the need for a pump and if the fresh tank were to be empty you might damage the pump.
Here's a good diagram that shows how it's all connected:
Direct Link To This Post Posted: 05 Sep 2012 at 6:28pm
Welcome to the forum.
Theoretically the pump shouldn't come on while hooked to city water, even if the power switch is turned on.  The pressure switch in the pump is set lower than most city water pressures.  Maybe the city water connection wasn't turned on at the campground's faucet?  Did you actually hear the water pump come on (you can't miss it)?
Note that you fill your fresh water tank from a different location than the "city water connection".  If I'm going camping where I know I'll have hookups I will only put a gallon or two in the fresh water tank for use while on the road (flush toilet, wash hands).  No reason to take 200 pounds of water with you if you don't need it.
Seanl View Drop Down
Direct Link To This Post Posted: 05 Sep 2012 at 9:56am
If you are using city water leave the pump off you don't need it. I was not even aware that the pump worked with the city water hooked up.
Direct Link To This Post Posted: 05 Sep 2012 at 9:44am
We just got back from our first trip with our new 2013 Rpod 177 and I have a question on the fresh water system. When we first got to our campsite, I hooked up the electricity and drinking water. On the second day, I wanted to check the gray water level so I used the monitor and checked all 3 tanks. I noticed that the freshwater tank was full and as I checked throughout the weekend, the level kept going down as we consumed water. My question is, (pardon the ignorance as this is the first travel trailer we have owned) once the fresh water tank is empty, does the pump automatically know to draw water from the city water outlet? Is there some switch over that has to be done?
I appreciate all the advise I can get.
2013 rpod 177
