  New Posts New Posts RSS Feed: Fridge in Auto Mode
Topic ClosedFridge in Auto Mode
mt868 View Drop Down
Direct Link To This Post Topic: Fridge in Auto Mode
    Posted: 07 Sep 2012 at 12:21pm
I have a Norcold fridge on my 2011 unit. If i put the fridge on auto mode and it has all 3 sources available (gas, AC, DC), is there an order that it chooses from?
I assume it would choose AC first, then gas, then DC?
this_is_nascar View Drop Down
Direct Link To This Post Posted: 07 Sep 2012 at 2:16pm
Yours is probably different since it's newer, but on mine, there's no auto cutover to any mode.  You must choose the mode manually, although it will run on either AC/DC/Propane.
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 07 Sep 2012 at 2:18pm
Sorry, just saw you  did say you had an auto-mode.  I'd expect AC is the default, then gas, then DC as a last resort, although you may have to manually switch to DC.
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 07 Sep 2012 at 5:49pm
Look for the model number, it might be on a sticker on the inside of the fridge.  Then you can look up the manual on Dometic's web site.  That will tell you the order.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 07 Sep 2012 at 8:19pm
If you search Norcold on the web it takes you to the Thetford site where there is a look up including RV friges.  It asks for the model number so you will need that.
Mine is a Dometic, so I can't help you.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 07 Sep 2012 at 8:26pm
Whoops, I said Dometic because that's what I have, meant Norcold.  :-)
