Yet more winterizing |
Post Reply | Page 12> |
Racer|X|
Senior Member Joined: 21 Mar 2012 Online Status: Offline Posts: 237 |
Topic: Yet more winterizing Posted: 06 Oct 2012 at 2:27pm |
Thank you MarW.
marwayne
Posted: 06 Oct 2012 at 2:25pm |
That is correct
Racer|X|
Posted: 06 Oct 2012 at 1:31pm |
Picture here...see the red (hot) on top in open position.
See the white (cold) on bottom in open position. Another valve in the middle has white coming in from bottom and red goes out of top and is in closed position. I assume I open this one and close the other two? Want to clarify.
Racer|X|
Posted: 06 Oct 2012 at 1:19pm |
Okay...winter isn't going to wait...cold today, decided to get going and do my first winterize.
Pod Possey....I have a question. I have a 182g. Under my dining table by my water heater are the bypass valves, I even found the pump and the hose piece to pump my rv anti-freeze. I can see a red and a white bypass valve. I understand which way to turn off. Now the confusion, there is a 3rd valve that is in closed position right now that runs between the hot and cold. Do I turn this ON? I have pics....but my dumb arse can't figure out how to post. **sigh**
Racer|X|
Posted: 11 Sep 2012 at 7:57pm |
Convinced...thank you all.
X
this_is_nascar
Senior Member Joined: 24 Jan 2010 Location: NJ Online Status: Offline Posts: 466 |
Posted: 11 Sep 2012 at 2:39pm |
Everyone, winterizing the POD is so inexpensive, quick and easy to do, it's not worth the risk in short-cutting things here. All it takes is for one valve or one connection that's wet, without antifreeze, to pop from freezing and it could be thousands of dollars in repairs.
"Ray & Connie"
Posted: 11 Sep 2012 at 1:24pm |
Since you connected the city water connection you have water in all of your lines. You need to do the full winterization.
http://www.rpod-owners.com/forum_posts.asp?TID=1723&title=creating-an-instruction-maintanence-manual
TIDALWAVE
Senior Member Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
Posted: 11 Sep 2012 at 11:12am |
After two seasons of winterizing...it doesn't take me long to air blow out the water lines (don't exceed recommended pressure). If you don't have the capability of air blowing the pipes...just use more antifreeze to assure that all of the untreated fresh water has been flushed out. Then turn the bypass valves, drain the water heater, and pump a gallon or two of RV antifreeze through ALL of the pipes.
TIDALWAVE
Goose
Posted: 10 Sep 2012 at 11:10pm |
I have to agree with dsmiths, don't do it cheap where you live. 10 to 20 below zero and pure water in some line maybe big problems next spring. Goose
dsmiths
Senior Member Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
Posted: 10 Sep 2012 at 8:55pm |
Racer dont take the chance, do it all and do it right, it only takes 2 gallons of r.v. antifreeze, its cheap insurance, trust me if the plumbing bursts or a tank bursts or something inside of a wall it will be much more to repair it.
Dane and Donna Smith
