  New Posts New Posts RSS Feed: plumbing schematic
Topic Closedplumbing schematic
RPodWeGo View Drop Down
Direct Link To This Post Topic: plumbing schematic
    Posted: 18 Sep 2012 at 11:10pm
RPod contacts @ this address:  http://www.rpod-owners.com/forum_posts.asp?TID=2747&title=misc-forest-river-contacts-and-other-info
RPodWeGo
RPod 177
04 v8 Toyota 4Runner
Rey View Drop Down
Direct Link To This Post Posted: 18 Sep 2012 at 5:59pm
It is a new 2011 model and under warranty.  I have returned it to the dealer.  I wanted to know if anyone had a schematic.  I always want to know the cause and how the remedy was done.  I don't know who to contact at R-Pod and I don't think they would give me that information.  It is my belief that the dealer does not have that information.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 18 Sep 2012 at 2:48pm
I take it this unit is no longer under factory warranty for some reason?
"Ray & Connie"
- 2017 R-Pod RP-180
Rey View Drop Down
Direct Link To This Post Posted: 18 Sep 2012 at 11:40am
I have just purchased a RP181G and have had a water leak.  The black tank flush line has either ruptured, maybe had frozen, or not connected.  A full blast of water sprayed between the shower and the small counter wall, water ran down from the tv outlet to the counter.  The piping to the black tank is run apparently overhead and down to the wet bath area and looped under the frame and connects to the black tank.  The loop of pipe under the frame appears as an after thought.  It will retain water and if not totally drained will freeze.  It is strange that this route was taken as the connection to the tank is only 2 ft away from the exterior hose fitting.  I am looking for a plumbing schematic, if there is one available.  If anyone has any help with this problem, it would be appreciated.  Thanks, Rey
