Sort-of Antenna Review |
Post Reply | Page <12 |
TIDALWAVE
Senior Member Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
Topic: Sort-of Antenna Review Posted: 27 Nov 2012 at 7:18pm |
I have a 'portable' digital TV with its own rod antenna and power supply.
I brought it with on my last trip with my Pod. The Pod's 'amplified' antenna/TV could only receive one channel. My portable set sitting out on a picnic table picked up five stations. However, when I brought the portable into the Pod...the aluminum roof killed all of the reception. I have decided that if I ever accidentally knock off my Pod roof antenna..a metal coat hanger will probable be as good an antenna. |
TIDALWAVE
P&M
Senior Member Joined: 13 Aug 2012 Location: Spokane, WA Online Status: Offline Posts: 454 |
Posted: 27 Nov 2012 at 10:09am |
I don't know if I think the antenna sucks, or if it is the overall dearth of over-the-air channels that are available anymore around here. 1 campground 5 miles away from Charlotte and I could only get 2 stations with 1 of them being fuzzy, and then this past weekend we were 20 miles away and I couldn't get anything. I could pick up radio stations just fine but no TV signals. Then again I'm not out camping just to sit around and watch tv, but I would like to check on the news in the morning since I am missing the paper.
P & M ... and Comet too!
2012 171 -- The Monkey Pod 2018 Ram 2500 |
TerryM
Posted: 26 Nov 2012 at 12:20pm |
Got that right! Terry |
Posted: 26 Nov 2012 at 11:19am |
Sounds like a good excuse for a camping trip.
TerryM
Posted: 26 Nov 2012 at 7:01am |
I have the amplifier. Where I store the Pod there is no electric so I can't check out the replacement TV. But I am thinking of going camping this coming weekend so I can try it then.
Terry |
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1216 |
Posted: 25 Nov 2012 at 10:57pm |
Terry happy to know you have had a use for the back up TV. What we did for antenna back up was install a exterior cable connector and connect a rabbit ear antenna and place it on the roof. It helps but if you are far from a TV station there is not much you can do. I do not watch much TV but my wife does, I could live without it. The weather on TV is nice to watch but a weather radio would be enough for me.
Racer|X|
Senior Member Joined: 21 Mar 2012 Online Status: Offline Posts: 237 |
Posted: 25 Nov 2012 at 7:11pm |
Yeah...my reception sucks too.
coopercdrkey
podders Helping podders - pHp Joined: 26 Aug 2012 Location: Cedar Key, FL Online Status: Offline Posts: 457 |
Posted: 25 Nov 2012 at 5:02pm |
We get strong signals close in to a metro area, not much in the boonies.
I give FR credit for their effort to elevate the R-Pod above the run of the mill. And I realize that they can't slam a whole bunch of bucks into a "high-end entry-level" travel trailer. (Is that an oxymoron?) Still, Audiovox is not held in much regard, and the Winegard antenna is pretty low end. Thanks, though, for a point-of-departure system that we can enjoy for a while! |
Bob and Joyce
Jennifer and Baxter, the Campin' Cocker Spaniels RP 177 "Key Pod" Chevrolet Silverado 1500 LT / Z71 |
dsmiths
Senior Member Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
Posted: 25 Nov 2012 at 4:05pm |
TerryM, I am not super impressed with the Pods T.V. performance, but I kind of did a comparison. I have a metal building that is 24X30, I have an external T.V. antenna on the north corner that faces toward local antenna's in the Louisville Ky metor area, I am in Lanesville Ind right across the river from Louisville. I Park and winter the pod on the south side of the building which should attenuate the signal slightly, I am guessing 6 ot 9 db, but the pod gets 20 plus channels and the T.V. in the building gets about 9, so I am guessing the amplifier is doing a fair job. does yours have the pre amp before the T.V. ?
Dane and Donna Smith
TerryM
Posted: 25 Nov 2012 at 2:58pm |
My TV doesn't work anymore but when it did I had a problem. I could never get more than 1 channel at the most. Usually none. One day I got up on the roof to do some cleaning and I bumped the antenna. It turned! I checked it out and the dish would spin around. I got some tools and the 2 bolts that clamp the antenna onto a pipe were loose. I grabbed the dish and pulled up and it came right off. The cable coming up through the pipe to the antenna was all twisted. It twisted so much it was disconnected from the antenna!
I had to redo the connector at the end of the cable. But the TV didn't work so I don't know if there was anymore damage to the cable or not. The problem was that the pipe wasn't big enough for the antenna to clamp good and tight to it. I solved that by using a Dremmel (sp?) to cut half of the clamping part of the antenna off. Then I shaved part of it so it would tighten down on the pipe. That part did work. I have a TV unit that is brand new and is exactly the same as the one in the Pod. We got it to keep in reserve as a backup. Good thing we did that too! Terry |
