Is there a trick to? |
Post Reply | Page 12> |
Topic: Is there a trick to? Posted: 22 Jan 2013 at 8:03pm |
I hope that the places that fill them all day long are more likely to get it right. New tanks are shipped filled with air and have to be bled out when filling for the first time. If you are using refilled tanks my bet is that they are fine.
secretbard
Senior Member Joined: 12 Apr 2011 Location: Budd Lake, NJ Online Status: Offline Posts: 195 |
Posted: 22 Jan 2013 at 3:28pm |
I actually buy my propane refills from Walmart or Lowes, so I'm not sure exactly what I'm getting. Do you think it would help if I just refilled my propane bottles at the local gas station? When you do a propane exchange, you never really know what you are getting.
2010 Rpod 172 :)
2004 Chevy Trailblazer |
Posted: 22 Jan 2013 at 8:24am |
have you made sure that the tank was fully purged prior to its first fill?
Our-pod
Newbie Joined: 17 Jan 2013 Online Status: Offline Posts: 20 |
Posted: 22 Jan 2013 at 2:50am |
The only time I've had a similar issue was when I had a partially clogged burner orifice in a furnace. The burner orifices in these furnaces are tiny. In my case, a little flake of dirt had traveled down the line. The furnace would light some of the time, but it seemed to have more trouble in the cold.
Sorry if my discussion of pressure and temperature wasn't clear. Unless you are really cold it should be fine, but temperature and pressure are directly related for gasses. |
secretbard
Posted: 21 Jan 2013 at 10:27pm |
I think I may have found the answer in an older thread:
http://www.rpod-owners.com/forum_posts.asp?TID=2604&PID=24690&title=furnace-wont-ignite#24690 It seems to me that the lines need to be purged and this might be accomplished through lighting the burners until the flames are good and blue. This still doesn't explain why my furnace would run and heat the pod, but when the tank got to the halfway point, the furnace would fail to light. Ah, I will have to figure this one out through trying what I've learned in the above thread.
2010 Rpod 172 :)
secretbard
Posted: 21 Jan 2013 at 8:51pm |
Do you know how I could unclog the partially clogged orifice? The furnace works and works well and is relatively new, so I really don't see there being an issue with the furnace itself. It does click to come on, at least I think it does. It could be the ignitor, but I really doubt it as with a full tank of propane, it clicks and comes on almost immediately. I'm thinking it might be a pressure problem where not enough gas is getting to the ignitor which very well could be a clog. I've already had the front panel off of the furnace. Any idea of how to clean out the lines? Thanks for the help. I always prefer doing any maintenance myself as this will help me learn how to care for my Pod. Maybe I'll look in the manual and see if I can figure it out. There really should be no reason why the furnace can't run until the propane tank is nearly empty.
2010 Rpod 172 :)
Posted: 21 Jan 2013 at 8:31pm |
Unless you are out in your pod in -20 F temps (or below), it sounds like you have a problem with your furnace. Possibly a partially clogged orifice. Propane evaporates from liquid to gas in the top of the tank down to -40 F, which is why they are never filled above 80% (and why pressure gauges won't tell you the level of fuel in the tank - another discussion) because it needs that empty area. However, at -40 F it will only support a very light load, like the fridge or stove. Once it gets fairly cold out propane will not evaporate as quickly to support heavier loads like the furnace. Without looking up technical details to figure out how low you can go and run the furnace, but I would guess you shouldn't have a problem down into the negative teens which is why I asked if you were out there at -20 F. If you are having problems and it is 25 F (above zero) then the propane supply isn't the problem.
Camper Bob
podders Helping podders - pHp Joined: 26 Sep 2011 Location: Portland Oregon Online Status: Offline Posts: 913 |
Posted: 21 Jan 2013 at 7:54pm |
Who's on first? Safe Travels.
Camper Bob and Camper Sue
Our-pod
Posted: 21 Jan 2013 at 3:58pm |
I haven't yet experienced this, but I'm guessing that it's due to the cold temperature effect on the gas pressure. It goes back to the ideal gas law: P*V=n*R*T, where P is pressure, V is volume, n is the amount of gas in moles, R is the gas constant and T is temperature.
For this situation, V, n and R are all constant - they don't change with temperature (alright, V changes slightly, but let's ignore that for now). So then you see that P is proportional to T - i.e. lower the Temperature and the Pressure will fall. It's possible that the furnace requires a little more pressure or flow than the other appliances, and this could be the problem. Filling the tank to 20lbs on a cold day would reduce the effect of temperature drop on the pressure. My two cents.
Our-pod
Posted: 21 Jan 2013 at 3:49pm |
