Portable Ceramic Heater Suggestions |
Post Reply | Page 12> |
Author | ||
Our-pod
Newbie Joined: 17 Jan 2013 Online Status: Offline Posts: 20 |
Topic: Portable Ceramic Heater Suggestions Posted: 04 Feb 2013 at 11:00am |
As most have said, just about any heater will work. A few things to consider:
Type: Don't get hung up on "ceramic" or anything else. 1500w is 1500w. The differences in fans can make a small difference, but the Rpod is so small that you're unlikely to notice it. Noise: Smaller heaters use small fans operating at higher speeds. This translates to more noise. Thermostat: Many heaters have thermostats that aren't very good. One major problem is that the thermostat is too close to the heat source. I personally have yet to find one that is repeatable. I'm considering buying this: http://www.amazon.com/gp/product/B000E7NYY8/ref=s9_simh_gw_p60_d7_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-3&pf_rd_r=1THRZAJ4S7CD5AAXSED9&pf_rd_t=101&pf_rd_p=470938811&pf_rd_i=507846 You can plug any old heater into it and have a good thermostat that is farther away from the heat source. I haven't used it yet, but it seems ideal for the need. |
danthoman
podders Helping podders - pHp Joined: 04 Aug 2012 Location: GA lake country Online Status: Offline Posts: 183 |
Posted: 02 Feb 2013 at 8:53am | |
Welcome to the forum Tars.
Linda and Dan
Calley the golden retriever R-pod 177 and a Tundra 8 cyl |
Posted: 01 Feb 2013 at 11:22pm | |
Welcome, Tars Tarkas.
dsmiths
Posted: 31 Jan 2013 at 8:41pm | |
We purchased an inexpensive one from either Target or Walmart, cant remember. It is a 1500 watt unit. it has blower only no heat, then 1, 2, or 3 blower and a variable thermostat, it also has a oscillate feature. I normally turn the oscilliation off, put the blower on 2 and set the temp to 1/3 or 1/2 or so. We have camped in the fall when the temps dropped down into the hi 20's and there was a hard frost (good white 1/4 inch coating on everything outside) The temps were 72 or 73 inside, and the heater would only run about every 20 minutes or so. We stayed as warm as two bugs in a rug. I think the unit was about $20.00 or so and has tip over protection. very quiet also. The factory pod heater does a good job, but that purge blower will wake you up every time, I guess you would get used to it over time. I like the electric heater better.
Dane and Donna Smith
Tars Tarkas
Posted: 30 Jan 2013 at 10:41pm | |
I agree with the ideas that just about any cheap 1500 watt heater will heat a pod just fine. At 30 degrees we had to leave the bathroom vent wide open to avoid condensation and we were toasty. I'd choose a heater that had a good thermostat and two heat settings. Other than that, maybe one with a remote control cause I'm too lazy to get out of bed to turn it down.
The tip-over switch is probably essential, but I'll bet you'd have to look pretty hard to find one without that feature. TT |
P&M
Senior Member Joined: 13 Aug 2012 Location: Spokane, WA Online Status: Offline Posts: 454 |
Posted: 29 Jan 2013 at 3:58pm | |
Oh man ... looks like I'm headed to Lowes for one of these!
P & M ... and Comet too!
Seanl
Posted: 29 Jan 2013 at 10:44am | |
I have this same heater. I have it on in my pod now and the temperature is 45 degrees and it is 2 degrees outside right now. It will heat the pod up to 70 in about an hour. If I want faster I just run the furnace to bring it up to temp and use the electric to keep it there.
danthoman
Posted: 27 Jan 2013 at 3:31pm | |
We bought a Delonghi at Lowes for about $25. It has a digital thermostat and oscillates which is nice. It also has a freeze mode which sets it to 45 degrees. We leave it plugged in and running all the time. When we used it in the North Carolina mountains it kept the pod nice and toasty even though it got into the 20's at night.
Linda and Dan
Goose
Posted: 27 Jan 2013 at 1:13pm | |
We just use a small inexpensive fan forced heater that has 2 heat settings to it. The only time that we have used it in the trailer is coming home from AZ. in Oct., it is generally cool over night in Tucumcari, NM. were we stop and need a little heat in the morning. Right now it is next to me on the floor to warm the back bedroom. The cheaper the better, if you only use it in the R-POD it will last a lifetime. This one we have had for over 10 years. Goose
tsunami123
Newbie Joined: 07 Dec 2012 Location: MINNESOTA Online Status: Offline Posts: 21 |
Posted: 27 Jan 2013 at 12:36pm | |
I use a metal pan beneath my heater that I set on the floor (to prevent a fire if the heater were to tip over). It allows warmed air to circulate from floor to ceiling; placing the heater on the stove creates two temperature layers in the Pod. My heater does have a 'tip over shut off'...but it is still pretty hot when it shuts off. My heater has 600&1500 watt settings. At 1500 watts it keeps the Pod quite warm even at below freezing temps. 1500 watts is close to 5000 BTUs. I open the shower ceiling vent slightly to allow some of the water vapor out.
When it gets below freezing...I have mylar-reflecting foil-bubble sheets cut to fit in the window frames. The sheets insulate the single pane windows from frosting up and also reflect unwanted sun light in the summer. |
