  New Posts New Posts RSS Feed: Pushout Seals
Topic ClosedPushout Seals
geelse View Drop Down
Direct Link To This Post Topic: Pushout Seals
    Posted: 08 Apr 2013 at 11:59pm
The weather stripping seal at the base of the  push out keeps coming loose, any ideas on how to solve problem?
See America First
2013 R-POD 177 HRE
2005 Dodge Dakota Quad Cab
George and Linda
hogone View Drop Down
Direct Link To This Post Posted: 10 Apr 2013 at 8:34am
I have the same issue, everytime I open the slide it comes off (the bottom seal).  And sometimes it gets pulled in when I close the slide.  Haven't found a good solution yet.
Direct Link To This Post Posted: 10 Apr 2013 at 10:28am
Ouch  You have described the issue perfectly. I'll let you know if I find a solution. I'm going to write Forest River.
See America First
2013 R-POD 177 HRE
George and Linda
Direct Link To This Post Posted: 10 Apr 2013 at 7:08pm
Welcome, hogone.
Direct Link To This Post Posted: 11 Apr 2013 at 12:13pm
OK Tek, what do you think? Have you run into this before?
See America First
2013 R-POD 177 HRE
George and Linda
Direct Link To This Post Posted: 11 Apr 2013 at 1:41pm
That is why I didn't want a slide out, I heared to many bad stories. My sons father in law has a fifth wheel, went camping, pushed the slide out but when it came time to go home the slide would'nt budge electric or hand krank. They had to get a tech to the campsite to fix it, then take it to the dealer to check everything out. Total bill 8000$ luckely under warrenty.
Kickstart View Drop Down
Direct Link To This Post Posted: 11 Apr 2013 at 2:21pm
Slides are just like electric windows in a vehicle--they might cause problems. Yes, they are something else that may go wrong, so you have to weigh the benefits. You pay extra and you maintain and repair as needed. I know in our case we've always towed small in that our largest trailer was a 22 footer. I also know that as much as we love our RP175, we would not have even considered the purchase without the slide. So, "to each his own".
'12 Toyota Tundra
'05 Sportster (half a Harley)
Retired-We're on Beach Time!
Direct Link To This Post Posted: 11 Apr 2013 at 5:21pm
We will never have a TT without a slide. It is the biggest downside of the 'stream, besides total length.
Yes they can have problems. Friends had one leak and rot, had to replace the whole thing.. Under warranty thank goodness..
Direct Link To This Post Posted: 11 Apr 2013 at 8:15pm
Sorry, geelse, no experience with this.  I had a manual slide-out in our popup but no slide-out on our 171.
Direct Link To This Post Posted: 16 Apr 2013 at 12:13pm
Thanks for the welcome techntrek.  Just back from 6 days in the pod, perfect trip.  Just to clarify to all, nothing wrong with the slide at all; works perfect (excellent seal in and out, perfect smoothe operation).  It's just that the bottom rubber seal comes off when you open the slide.  Prior to shutting this time, I sprayed a little silicone on it to help keep it a little more moist and lubricated, but that's not a fix.  Not extremely worried about this, sure there is a simple solution which I will figure out.  hogone
