  New Posts New Posts RSS Feed: refrigerator in RPOD (Dometic)
Topic Closedrefrigerator in RPOD (Dometic)
hogone View Drop Down
Direct Link To This Post Topic: refrigerator in RPOD (Dometic)
    Posted: 21 Sep 2013 at 8:07am
Aren't there alot of camper/rv fridges that do not even have the battery option?  Personally I tow in battery mode but really do not have any fears of towing with gas as I'm sure as mentioned by others there are safety features which would minimize the dangers.
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
CharlieM View Drop Down
Direct Link To This Post Posted: 21 Sep 2013 at 9:58am
Yes, most of the larger fridges are two way with no 12 volt option. They are auto senseing, using 120 volts if available, but switching to gas otherwise. In the old days, before auto-ignition when pilot lights had to be manually lit and could blow out while driving, battery operation became common on the road. However, todays smart fridges, better RV/fridge design, and safer gas bottles, make gas operation on the road safe and convenient. Your 20+ gallon gasoline tank is indeed more of a hazard,
Sleepless View Drop Down
Direct Link To This Post Posted: 21 Sep 2013 at 10:44am
I agree with all the comments about towing in propane mode is safe.  However, we should all remember to extinguish all flames, be it the water heater or the refrigerator, before you are near gasoline pumps.  I don't want open flames or lit cigarettes near me when I am pumping gas.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
gpartmann View Drop Down
Direct Link To This Post Posted: 21 Sep 2013 at 10:55am
- panel with resets (breaker switches) and fuse boxes is under table on front panel of back bench in my model
-yes, make sure everything is off at gas pumps....and you will be stopped going in to some tunnels to show that propane is off before being allowed to procede
-basically, I bought a model with 3-way operation and I want that to work (which it now does since dealership repaired frayed wires  (why did wires fray?  poor design?  don't know)
ghp in Sonoma
Direct Link To This Post Posted: 21 Sep 2013 at 10:57am
To answer the question on the last page, all of the 12 volt fuses and 120 volt breakers are on the front of the converter.  I believe on all pods (and most campers) it is in the front-left near the floor.
Direct Link To This Post Posted: 21 Sep 2013 at 11:00am
The flame issue isn't as big of a problem as you might think.  Gas vapors sink so they won't contact the flame in the fridge 3 feet off the ground.  Gasoline also has a narrow combustibility range (there is a technical term for this) - too much or too little and it won't go boom.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 21 Sep 2013 at 3:33pm
And then there was the urban legend that a cell phone ringer could set off gas fumes at the pump, even though it was solid state and no spark possible.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 21 Sep 2013 at 4:38pm
Yup, that one, too.
Kickstart View Drop Down
Direct Link To This Post Posted: 21 Sep 2013 at 5:07pm
Problem for us in Washington State that most of you don't have to deal with is that WSDOT requires all propane tanks to be shut off on any WA State ferry, and we have a lot of ferry runs here in Puget Sound. I dunno if the requirements are the same in BC, but there's a lot of ferry traffic up there, too.
'12 Toyota Tundra
'05 Sportster (half a Harley)
Retired-We're on Beach Time!
Direct Link To This Post Posted: 21 Sep 2013 at 5:31pm
It's the same in BC.
