Post Reply | Page <1 1516171819 87> |
Author | ||
Leo B
Topic: Pictures of tow vehicles and trailers Posted: 02 Apr 2018 at 4:17pm |
Nice set up!
Massucci1
Newbie Joined: 01 Apr 2018 Location: Ohio Online Status: Offline Posts: 12 |
Post Options Quote Reply Posted: 02 Apr 2018 at 9:34am | |
Yep 178, my screaming 6 month old child waking me at 4am makes my brain tired. |
Post Options Quote Reply Posted: 02 Apr 2018 at 9:02am | |
Congratulations and welcome! Forest River has made a number of changes on the 179 since we purchased ours in December, 2015, but I think you have something other than a 179 since the door is in the wrong place. Did you mean 178? I hope you have a lot of fun adventures with your R-Pod and make many great memories in the process. |
Massucci1
Post Options Quote Reply Posted: 02 Apr 2018 at 8:56am | |
Leo B
Post Options Quote Reply Posted: 30 Mar 2018 at 5:39pm | |
Hi, We towed our 171 and 179 with a 2013 Dodge grand Caravan mostly up and down the east coast from Vermont to Florida numerous times and back and forth to North Carolina. We had plenty of power and go fairly decent mileage. We towed over the years probably over 20,000 miles. never had issues and we still have our van and it still runs great. Last year we upgraded to a Ford F-150.
Post Options Quote Reply Posted: 30 Mar 2018 at 3:07pm | |
I can't say that. You would need to have more input from owners of Caravans that have towed.
lamyber
Newbie Joined: 31 Aug 2017 Location: Trois-RivierQc, Online Status: Offline Posts: 3 |
Post Options Quote Reply Posted: 30 Mar 2018 at 2:45pm | |
Thanks for your reply. Yes i will install all the kit to be safe And yes we want travel across de Cnd and usa. So do you thing the 177 r-pod will be ok. There are just my wife and me. No pet no child no bick. Am i wrong if i gues that the total Max pound will be around 3000/3200. |
Bernard and Julie
Dodge Caravane set 2016 V6 3.6L and Soon owns a 2018 R-Pod |
Post Options Quote Reply Posted: 30 Mar 2018 at 1:35pm | |
Now "maybe" you won't load it up with 1300 lbs of gear, but you'd be surprised by how much you might add without really trying. I would say that is too much for your van. |
Post Options Quote Reply Posted: 30 Mar 2018 at 1:30pm | |
Postimage.org is the site used by some. I host my own images, but not everyone has the equipment or knowledge or time to do that so Postimage.org works.
As for the 180 with a Caravan, if you tow on relatively flat terrain, it may be okay. Don't try it in the mountains though as you will be very much disappointed. We were towing our RP179 which is roughly the same size and weight as the 180 with a 2016 Ford Escape SE with 2L Ecoboost engine. That also had a 3500 lb tow rating. It worked well but I knew the limitations. After we encountered ice with a very strong crosswind, we had an accident and had to change tow vehicles. I now tow with a 2010 Frontier 4x4. While the V6 is twice the size, the power of the Ecoboost showed in mountains as it does not lose power like the non-turbo or supercharged engines do. One thing is whether your Caravan is FWD or AWD. If it is FWD, you will absolutely need a Weight Distribution Hitch, preferably with sway control such as the Equal-i-zer or the Fastway E2 or the Andersen No-Sway. This will be needed to make sure you have enough weight on the front axle for traction and steering. Even with the WDH, traction with the Escape could be marginal if the road were slick and probably nearly impossible if we needed to start from a stop uphill on a dirt road. The Frontier is manual 4x4 but the primary drive axle is the rear axle so it does not have the same issue as the Escape and possibly your Caravan. I'm not saying it won't work, but be aware of the issues. I wish you well in your search for the R-Pod that is right for you and your family. We have enjoyed ours and I have done a number of modifications to it to make it even better and more suited to our use. |
lamyber
Post Options Quote Reply Posted: 30 Mar 2018 at 12:41pm | |
Hello Patrick, my wife and I are about to acquire a R-pod but the model is not final. We have a 2016 Dodge caravan with a towing capacity of 3500lbs like your car. we thought of the model 177 to 2500lbs to have room marge with the vanne, but it is certain that the model 180 is larger. Your comment and all comments from the owners of R-pod are welcome to enlighten us
