  New Posts New Posts RSS Feed: First trip
Topic ClosedFirst trip - Event Date: 07 Jun 2013 - 09 Jun 2013
Zag View Drop Down
Direct Link To This Post Calendar Event: First trip
    Posted: 10 Jun 2013 at 4:10pm
Originally posted by Seanl
yes check valve failure is my guess as well. This is what the check valve looks like with the screen removed. That little white pin is the the back of the check valve. My guess that the spring and plastic were part of of the valve that came apart. There is normally a screen over the check valve so it looks like the bottom picture.
That's it for sure.  Clap Glad my buddy saw and picked up the piece of plastic and spring from the push.
Anybody know what the process is to fix/replace the check valve?
2009 RP-152 (Cutie-Pod)
2001 Nissan Pathfinder
Seanl View Drop Down
Direct Link To This Post Posted: 10 Jun 2013 at 4:05pm
bhamster View Drop Down
Direct Link To This Post Posted: 10 Jun 2013 at 2:18pm
Originally posted by Zag
Any thoughts on what might have happened based on the symptoms?
Sounds like your check valve failed. The check valve allows water to flow into the city water connection, but not out of it. You should be able to replace it fairly easily.
On a related note... this is why I never leave my pump on. Even something like a leaky faucet (or something bumping the faucet handle) will cause the tank to drain without you knowing it. Leaving the water heater on won't hurt water or electricity consumption much, but will use extra propane.
Zag View Drop Down
Direct Link To This Post Posted: 10 Jun 2013 at 1:20pm
Hey Pod Owners,
Here's a little story about my first outing with 'Cutie-Pod'.
I had a 7-pin connector and brake controller installed the day before and took the TV and trailer out to the local Costco after hours to set the controller and get comfortable with backing up (thinking about the tight camp site entrances). For other first time RV owners, this is a great tip!
The next day I left with a buddy on the inaugural journey. We pulled in to the nearest gas station to fill up and I didn't approach the entrance at an angle so ended up scraping the back end of the trailer. Looks like I took a bit of the underlay off  where I touched so I'll have to figure out how to patch that up.
Otherwise a comfortable 90 minute road trip to the campground. The road had some dips that made the trailer bounce a bit but it seems no worse for wear and everything in the trailer survived. Managed to back up into my space on my first attempt (with the guidance of my buddy).
Followed the many tips and posts on the forum and had the Pod all set in under 15 minutes.  It took us a little longer to figure out how to switch the fridge from battery to propane. By chance I tried resetting the power with the fridge set to propane and that initiated the pilot light; after that it was all good.
Had a strange thing happen on day two. I had been turning the water pump and water heater on and off as I needed it (thinking about battery conservation(. As the day progressed and I saw we still had plenty of battery I turned on the pump and heater and kept it on. After a while I hear water gushing out of the side of the RV and see water (clearly under pressure) coming out of the city water intake. It was the fresh water and the tank emptied. We found what looks like some sort of spring and piece of plastic on the ground afterwards which might be part of the pressure valve? I spoke to a couple of RV'ers at the waste station and I don't think I did anything wrong by leaving the pump and heater on so I'm assuming I had some sort of failure with the water system.
Any thoughts on what might have happened based on the symptoms? I'll post a pic of the piece I found on the ground later.
Otherwise it was all good. Actually it was great! Hopefully my two incidents won't be too costly to address. Can't wait for the next outing!
Direct Link To This Post Posted: 05 Jun 2013 at 9:36pm
Originally posted by Outbound
BTW: your black tank gauge WILL gum-up and constantly read full.  Don't worry about it.  Don't spend endless hours with a spray wand down the toilet trying to clean them off.  Just live with it.  It'll take two people over 10 days to fill your black tank.
Good point, completely true.  The best indicator that your black tank is full is when you start seeing fluid come back up the tube when you flush!  Dead  (not kidding)
Direct Link To This Post Posted: 05 Jun 2013 at 9:29pm
Originally posted by Kickstart
Don't forget to chock your trailer wheels...
Dang, I did forget that very important step!
CharlieM View Drop Down
Direct Link To This Post Posted: 05 Jun 2013 at 1:19pm
Yes, the coiled hose works well IF someone has put a standard male garden hose connector on it. Some I've encountered had a short wand installed; probably from the original installation before newer campers had the black water flush connection.
Also, I like to close the dump valve and let the black tank fill about 1/2 so there is a lot of water to flush out. However, you have to watch the tank level carefully or you'll understand why the caution on keeping the dump valve open is pasted on the side. Censored
coopercdrkey View Drop Down
Direct Link To This Post Posted: 05 Jun 2013 at 11:28am
I have noticed at several dump stations a coiled, extendable hose long enough to reach the black water
tank flush input.  As long as your dump hose is in place and your black water valve is open, you can run
fresh water into and out of the tank until you're satisfied it has been well purged.
Bob and Joyce
RP 177 "Key Pod"
Direct Link To This Post Posted: 05 Jun 2013 at 9:59am
I always carry two pair of cheap plastic chocks-always use one pair, and sometimes both if necessary.
I'd recommend getting and using two pairs. They're cheap and easy to use. That way you don't have to guess which way everything will roll. I had one time where it moved unexpectedly and after that I always used all four.
Outbound View Drop Down
Direct Link To This Post Posted: 04 Jun 2013 at 8:45pm
With levelling, pick your poison.  I suggest that you go with either a Bal leveller or with Lynx Levellers (legos) and stay away from wood (sorry guys) or those step-like all-in-one levelling blocks.  Personally, I use legos.
For the black tank, as I'm packing up the trailer before pulling out of the campground, I'll run water into the toilet and fill it to at least the 2/3rds mark.  A well positioned soap/shampoo bottle in the corner will keep the toilet flush pushed in.  As tech said, the volume of water will help completely empty the tank.  Also, after visiting the dump station, I'll fill the toilet with water, add some toilet treatment and flush (leaving it in the black tank).  The sloshing water/chemicals will work on the sludge as you drive down the road to your next stop.
