2012 Rpod 177 problems |
Post Reply | Page 123 5> |
dshearer
Newbie Joined: 12 Jun 2013 Location: Montana Online Status: Offline Posts: 12 |
Topic: 2012 Rpod 177 problems Posted: 17 Jun 2013 at 4:03pm |
Unfortunately, the latest in a line of problems with our 177 is the axle failure which will cost about $900.00, waiting 6-7 weeks for the part, and not covered by warranty. We are extremely disappointed. Other issues have been: rear window leak, DVD falling off cabinet numerous times, lights falling off ceiling, lose clamp under slide-out (clap pushing on slide-out facia causing it to catch the screws), loose wiring on monitor panel for black and grey tanks (tanks not reading properly), furnace grill continues to fall off when traveling, table rubs the front camper wall, sink was not tightened down and moved out of position, and screws fell out of brackets holding dump valves.
I'm sure some might wonder how we care for our camper, it's our first new camp trailer and we are extremely careful with it. Anyone else having similar issues? |
Montana camper
Seanl
Posted: 17 Jun 2013 at 5:08pm |
Nope I had an issue with the Ac that was repaired under warranty and thats it.
danthoman
podders Helping podders - pHp Joined: 04 Aug 2012 Location: GA lake country Online Status: Offline Posts: 183 |
Posted: 17 Jun 2013 at 5:11pm |
Wow, we haven't had any problems like that. Everything has worked fine except for the black water tank monitor and connecting a hose (not a drinking water hose) to the spray inlet to help clean the tank when emptying solved that. Most all the problems mentioned should have been fixed under warranty.
Also, welcome to forum. |
Linda and Dan
Calley the golden retriever R-pod 177 and a Tundra 8 cyl |
Craneman
Senior Member Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Posted: 17 Jun 2013 at 5:15pm |
Were these items covered by factory warrantee ?
Moe
Goose
Posted: 17 Jun 2013 at 5:29pm |
That's sad to hear of all your problems. Do you travel with the table set up when you travel, this I could see rubbing the front wall. Goose
Posted: 17 Jun 2013 at 7:16pm |
Welcome. What year is your pod? Did you buy it from a dealer (new or used) or from another owner?
Keith-N-Dar
Posted: 17 Jun 2013 at 7:36pm |
Ours is a 2011 and has been nearly trouble free. Ours was made in Indiana. Was yours made out west?
Keith-N-Dar
P&M
Senior Member Joined: 13 Aug 2012 Location: Spokane, WA Online Status: Offline Posts: 454 |
Posted: 18 Jun 2013 at 11:52am |
We've had one or two minor issues with ours since buying it last October, but nothing like what you have encountered.
P & M ... and Comet too!
hogone
Senior Member Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1049 |
Posted: 18 Jun 2013 at 12:47pm |
I have had no major issues as of yet, granted it's only a year old. When I purchased, I did buy the extended warrenty. Never in my life have I purchased an extended warrenty on anything, not quite sure why I did on the pod. Maybe for piece of mind, but then how good is it actually if I were to use. One thing I have noticed however is when my air conditioner compressor goes off there is kind of a thumping noise.
Jon & Pam
Posted: 18 Jun 2013 at 2:31pm |
Thumping is normal, if you can call anything about the A/C normal.
I, too, never buy extended warranties but did for the pod.
