Air Conditioner |
Post Reply | Page 123 5> |
Kickstart
Senior Member Joined: 20 Sep 2010 Location: Ocean Shores, W Online Status: Offline Posts: 267 |
Topic: Air Conditioner Posted: 27 Aug 2013 at 6:14pm |
We have not used the Polar Cub extensively yet, but have been satisfied so far with both its performance and noise level. Also, now that I've towed the pod numerous times with the Polar Cub on top, it must really upset the wind drag at the back of the Pod (the Cub is longer and more squared off at the rear than the factory installed Dometics). My towing MPG has increased. In 2.5 years before the recall wing and A/C install I had one tank over 13 MPG and now twelve tanks at 13-14.4 MPG since.
'12 Toyota Tundra '05 Sportster (half a Harley) Retired-We're on Beach Time! |
Seanl
Senior Member Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
Posted: 27 Aug 2013 at 12:09pm |
All AC units have a temperature sensor that shuts down the compressor when the coil temperature gets too low this is to stop the cooling coil form freezing up. The sensor went on mine when I first got it and the AC would shut down when the coil froze up and then it would melt and dump water all over the floor.
hogone
Senior Member Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1043 |
Posted: 27 Aug 2013 at 9:32am |
Wow, thanks. I'm going to do a better inspection.
Jon & Pam
sammycamper
Senior Member Joined: 23 Oct 2012 Location: Minnesota Online Status: Offline Posts: 111 |
Posted: 26 Aug 2013 at 5:43pm |
Hogone,
The worst areas were around the refrigerator and the hoses to/from the hot water heater. You can see in the first two pictures, taken from the back of the refrigerator, where the dealer filled significant spaces with yellow foam. The third picture shows the hot water heater area. They also installed foam around the vent openings.
Basically, anywhere that there is a hole or cutout through the wall, floor, or ceiling of the camper should be sealed. That wasn't done by the factory, and the air leaks made our rPod virtually impossible to heat. We could feel a significant breeze next to the refrigerator that first night out, and I stuffed paper towels between the fridge and the wall inside the camper to slow it down temporarily.
Sam
2012 rPod 173
2008 Trailblazer 4WD V6 |
Sleepless
Senior Member Joined: 07 Jun 2013 Location: Titusville, FL Online Status: Offline Posts: 556 |
Posted: 26 Aug 2013 at 5:30pm |
I asked the original owner of my pod about the A/C unit. He assured me that the Coleman unit was factory-installed. I checked my owner's manual and the 2010 specs and found out that the 2010's came with an 11K BTU unit. Apparently FR switched to Dometic at a later date and changed the size from 11K BTUs to 13.5K. I don't know this for fact, just guessing. Bob |
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche |
hogone
Posted: 26 Aug 2013 at 4:32pm |
Over the weekend I did crank it down to 65 (per my own thermometer, not the thermostat reading as this is not accurate). So I do no it can get down that cold.
Jon & Pam
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1216 |
Posted: 26 Aug 2013 at 4:21pm |
I have read the Dometic AC has a automatic shut off when it reaches a factory set low temp. I read the Coleman too has a factory low temp set where it will shut off. The difference was said that the Coleman will be aloud to reach a colder temp than the Dometic before the compressor turns off. As far as I know all factory installed AC's in the r-pods are the Dometic brand. If we could afford it we would like to replace the AC with a quieter AC but until the Dometic wears out and needs replaced we will be keeping it. David
hogone
Posted: 26 Aug 2013 at 4:02pm |
Sorry, that question regarding lack of foam should of said "sammycamper". I guess I'm still wondering what a smaller a/c unit would do; actually cool better, less noisy, more environmentally friendly, ???; or all them. I would bet it costs more to cool my pod than my house seeing how hard and often it runs.
Jon & Pam
Sleepless
Posted: 26 Aug 2013 at 3:30pm |
That must have been another member. I bought my pod used and have never taken it to a dealer. Bob |
Posted: 26 Aug 2013 at 3:04pm |
Yes, I notice a definite thump when the compressor cycles on. We keep the fan set to "on" partially for the white noise (to mask the compressor cycling, and outside noise), partially to keep the air temp uniform all over.
