r-Dome Revisited |
Post Reply | Page <1 23456 12> |
2PeasNRPod
Newbie Joined: 07 Sep 2013 Location: Oklahoma City Online Status: Offline Posts: 6 |
Topic: r-Dome Revisited Posted: 10 Feb 2014 at 6:53am |
Sorry correction, 2014 178
Mimi
Brett - Pea #1 Mimi - Pea #2 2014 178 |
2PeasNRPod
I've searched threads regarding the Rdome. My husband and I have decided to purchase one for our 2013 178 with Risers. From my research the only seller is Dometic but I still have questions
Does anyone know of a better seller? If Dometic is the best, is their Cabana what we call the Rdome? What size do I need? I can find it by model number that was listed in an earlier post Thanks
Mimi
Kokopod
Senior Member Joined: 26 Feb 2013 Location: Southwest WY Online Status: Offline Posts: 113 |
Posted: 08 Feb 2014 at 12:31am |
The biggest trick is to seal it around the tire and screen skirt under the Pod steps and especially in the corners. We've managed to get it pretty tight in those areas. We do get an occasional mosquito; but for the most part, we're pretty bug free.
2017 Jayco Melbourne 24k
2013 Premier 19FBPR Formerly-2013 R-pod 177HRE 2011 Dodge Durango Love a good road trip |
SchipperPod
Groupie Joined: 06 Sep 2013 Location: Utah Online Status: Offline Posts: 81 |
Posted: 07 Feb 2014 at 1:36pm |
So, Kokopod, do mosquitoes get in under the pod itself and into the R-dome?
Happy tails and trails!
Teri & Jeff Black Plus 4 Schipperkes: Kodi, Jessie, Maggie & Bear 2014 R-Pod 178 2013 Santa Fe Sport Turbo |
Kokopod
Posted: 07 Feb 2014 at 1:20pm |
We've used our dome at least 30 times. It will withstand some wind (in Wyoming it's always windy), but we do take it down when the wind is extreme. It survived a 2", 2-hour hail storm last summer in the mountains like a champ, except we kept having to knock the ice off of the sagging roof area. Yes, we've had to play around with it to figure out the best way to get it through the track (like others, we filed things down a bit and it now goes in perfectly), had to figure out where to place the suction cups (the first picture on the first page of this thread is how we do it), and depending on the slope of the land it sometimes doesn't touch the ground the way we'd like (we also have the HRE), but all in all it's a terrific product. We sat in the R-dome at a campground in Myrtle Beach night after night when the big rig people were inside because the bugs were fierce, and we were just as cozy as can be. Let me tell you, those big-rig people were jealous, and many of them commented about how awesome it was that we had that screen tent.
G-Force
Newbie Joined: 02 Oct 2013 Location: Bozeman, MT Online Status: Offline Posts: 10 |
Posted: 07 Feb 2014 at 11:38am |
I bought an R-dome with my 178 Hood River Edition last fall. Had the same issues others have - needed to figure a system for sliding it through the metal channel w/o cutting into the fabric: silicone spray, filing the sharp channel edges down, and working it past the original screws lets me put it up alone. The additional height of the HRE though is an issue. They only make the R-dome in one size, so with the extra height of the HRE and the extra length of the 178, the R-dome sits higher off the ground than it should and it slopes from the rpod down to the poles. Looks wrong, but works OK. I didn't find it to be very stable in wind at all, but maybe its because of the poor fit with my HRE 178.
Podsible Dream
podders Helping podders - pHp Joined: 03 Dec 2010 Location: Hightstown, NJ Online Status: Offline Posts: 571 |
Posted: 17 Jan 2014 at 5:02pm |
We went with super stick 2" Velcro on the flaps of the dome and stuck to the pod wall. Some areas peeled - not cleaned enough? And some areas pulled the 'decal's ' off. The other thing is the white Velcro is whiter than the pod coating, and it collects dirt. However, the flaps are stuck to the wall with no openings or drafts. As I said in an earlier post, I made 8x8 blocks from 4x4's with a hole in the center for support pole which brings the front of the dome to the same height as the pod end. We often use extra firewood to hold down the side and front flaps.
Walt |
Chris and Walt
'10 RP-171 'Free Spirit' '13 Dodge Durango Crew 5.7 L Hemi V8 |
kymooses
Posted: 16 Jan 2014 at 4:29pm |
when we put up our dome on our 181g i'll try and take the suction cups just to the left of the storage bin so that we can still access it. like you said though it is a bit troublesome at times.
juzdon
Newbie Joined: 05 Aug 2012 Location: Wisconsin Online Status: Offline Posts: 11 |
Posted: 16 Jan 2014 at 1:41pm |
i have a 181g and the r-Dome does not work the greatest with the garage component, plus i have risers, so it throws the height off to stake it properly. That being said, i never camp without using the r-Dome! i love it.
i attach the r-Dome so it's staked properly in front by the hitch and can use the suction cups on the front portion. the back end towards the garage, i use short bungee cords and good stakes to secure it to the ground. the suction cups at this end have to be attached to the side of the r-Pod, so i need to make sure i have access to the rear-side storage compartment or have it emptied out. as someone else mentioned, i took a Sharpie and marked the half-way point on the support pole that is threaded through the half dome. once, i got a system down, it's a breeze to set up by myself. the picture below shows how the r-Dome looks for me with the garage component. |
Posted: 03 Jan 2014 at 12:43pm |
We are honored to view your thumbnail.
