Tow Vehicle ground cable |
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1218 |
Topic: Tow Vehicle ground cable Posted: 26 Feb 2014 at 4:57pm |
I have been following a topic on the Dodge ram forum changing the ground cables to 4 gauge and I believe adding additional ground cables. The results are that headlights are brighter,engine starts faster and best of all better MPG 1.5 MPG better. There is quite a discussion about this and some are being persuaded to make the change including myself. What is being said is that it should not affect warranty or do any harm to your vehicle. My question is does this make any sense to anyone or has anyone heard of this before?Techntrek I thought this would be a good question for you or anyone else with knowledge of electricity. There is about 10 pages of discussion on this topic and growing. They get into a lot of detail even similar experience with aircraft engines. All comes down to having less resistance with the flow of electricity the way I understand it. Any information would be helpful. Thank you David
CharlieM
Posted: 26 Feb 2014 at 5:30pm |
Ah yes! Mysterious vapors are rising from the marsh. If you breath deeply you will be transported to the mythical land of milk, honey, and MPG.
That said the only place where this might make any sense is the negative wire from battery to frame. That might make a tiny improvement in starting, but you would probably not notice it. Everything else is either mounted to the engine frame such as starter and alternator, or is much lower current draw such as headlights, blower, and accessories. Replacing each of these ground wires with #4 would cost $$$ and weigh ###. Not practical, and unnecessary. As for increased MPG, see paragraph 1 above. P.S: Of course this assumes the Ram has not been converted to an Electric Vehicle |
Posted: 26 Feb 2014 at 8:54pm |
My guess - larger ground straps mean lowered resistance. Lower resistance means higher voltage, so the battery recharges faster and other electric accessories use less amps. Lowered load on the alternator means less gas used.
CharlieM
Posted: 26 Feb 2014 at 9:06pm |
Doug,
You're right that the battery will recharge slightly faster if the negative lead is upgraded, but the difference will be minute if the original is reasonably sized unless the battery is severely discharged. Most every other DC device except a constant power switching converter will draw less current with less voltage, but the difference in effectiveness will be barely noticeable. Where and RVer can improve with bigger wire is the trailer charging line to the TT. That usually is a good candidate for upgrade. |
Posted: 27 Feb 2014 at 4:29pm |
Absolutely - I always suggest 8 or 10 gauge wire for the +12 line running to the Bargeman, and the same for the ground IF it isn't attached to the frame close to the Bargeman.
