Tow Vehicle / Honda Pilot - Event Date: 13 May 2014 |
Post Reply | Page 12> |
johnandwendee
Newbie Joined: 11 Mar 2014 Location: Ontario, Canada Online Status: Offline Posts: 35 |
Calendar Event: Tow Vehicle / Honda Pilot Posted: 13 May 2014 at 9:21pm |
Hello All! Not sure how to do this but we have just purchased a 2015 /179 and pick it up June 25th. We have a 2014 Honda Pilot EX 4WD, the manual advises against WDH altho' our RV dealer recommended it. I have to explain that the RV dealer recommended prior to knowing the TV....does anyone have any clarification on this topic. Hopefully you are not going to tell us that we purchased the wrong TV!! We are very much looking forward to our new RPod....we have downsized from a2007 24' Forest River Wildcat 5th wheel....are we nuts or what??!!
John and Wendee
Bracebridge, Ontario Canada |
sailo25
Newbie Joined: 21 Mar 2013 Location: Michigan Online Status: Offline Posts: 37 |
Posted: 13 May 2014 at 9:27pm |
I pull a 151 with a 2013 pilot with a sway bar but not a wdh it pulls nice. I would try without if you need one the suggestion on this list is just don't lift to much with the wdh.
Paul & Karie
2009 151 2013 Honda Pilot |
CharlieM
Posted: 14 May 2014 at 8:07am |
I towed a 172 with a 2010 Pilot 4WD and E2 WDH hitch. I'm a firm believer in WDH and sway control for towing comfort and safety. The Honda book is a bit nebulous in this area. My 2010 book indicated they didn't recommend WDH because an improperly adjusted WDH could be damaging and dangerous. That is certainly true as I found out when I drove off the lot with the dealer installed setup. They actually had the brackets on up side down! After correctly installing and carefully adjusting the hitch I was pleasantly amazed at the difference. I don't interpret the Honda wording as a prohibition of a properly installed and adjusted hitch. Although I've traded up to a larger TT and TV I continue to preach the benefits if WDH and sway control. One other consideration is the unibody construction of the Pilot. That construction is not as strong as a conventional frame and MAY have entered into Honda's thinking. However I've never found that mentioned anywhere else so I don't know. I towed the Pod for a year and thousands of miles and never had a problem. Again I emphasize: Get the hitch manual, Read it, Understand it, and properly adjust the hitch. This is critical, but once done, will be well worth it. Run a search on this forum using the advanced search function and searching for my user name and Pilot for more of my ramblings. Good luck and let us know how you progress. |
podsuperior
Newbie Joined: 13 Oct 2011 Location: Northern MN Online Status: Offline Posts: 28 |
Posted: 14 May 2014 at 9:19am |
We tow our 177 with a 2007 Pilot - that lists the towing capacity at 3500#'s - I think the new Pilots are 4500#??
I did add a anti sway bar after a few years of towing without one - it is a noticeable difference on windy days - so I feel it was worth the $$. It tows just fine in my view for local trips (few hundred miles), if we were going to spend weeks / months traveling, especially in mountainous areas I would love something more powerful. |
2011 RPOD 177 - 2017 Tacoma
SeaPod
Newbie Joined: 28 May 2014 Location: Mississippi Online Status: Offline Posts: 7 |
Posted: 29 May 2014 at 11:59am |
We picked up our 2014 R179 last weekend and a tv came with it. Hubby towed our R Pod home from Schererville, IN to the gulf coast of MS with our 2013 Honda pilot with no sway bar and no problem. Our mpg dropped to 12 traveling at 65 to 70 mph. We are not 4wd. The transmission cooler was installed, and he also had a brake controller installed. Pulled great.
SeaPod
2014 R-179 2013 Honda Pilot |
Sleepless
Senior Member Joined: 07 Jun 2013 Location: Titusville, FL Online Status: Offline Posts: 556 |
Posted: 29 May 2014 at 12:08pm |
You must have gone to Rollin On in Schererville. That used to be our RV dealer until we moved from Schererville to Florida 12 years ago.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche |
Posted: 29 May 2014 at 2:19pm |
Welcome.
SeaPod
Posted: 29 May 2014 at 10:09pm |
We got our r pod from petes RV in Schererville sleepless
SeaPod
Sleepless
Posted: 29 May 2014 at 10:37pm |
Pete's was not there during our 35 year stay in the area. Rollin On and Campland were the only RV dealers in the immediate vicinity. Times do change.
Newsguy12
Groupie Joined: 30 Mar 2014 Location: Nathrop, CO Online Status: Offline Posts: 54 |
Posted: 29 May 2014 at 11:20pm |
John, we just picked up our 179 at Couch's a few weeks ago and drove it to Colorado last week. Our TV is a 2014 Jeep Cherokee Trailhawk with V6 and tow pkg. I've pulled larger trailers for years and always used a WDH. Not needed with the Pod. It pulled beautifully with only an anti-sway bar I installed myself. About 800 miles into our trip, my wife asked "is it still back there?" Not all vehicles tow alike, but the Pod only dropped my TV hitch about an inch and the vehicle and Pod are level. Whether driving across the plains or pulling up into the Rockies high country, the whole rig handled beautifully.
Ram 1500
5.7L V-8 Hemi 2015 R-Pod 179 |
