Important - check this every time you set up |
Post Reply | Page <1 202122 |
Topic: Important - check this every time you set up Posted: 28 Jun 2020 at 6:15pm |
+1
Pod People
Senior Member Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Online Posts: 1067 |
Post Options Quote Reply Posted: 29 Jun 2020 at 11:41am |
I made a simple 30 amp electrical tester that will show the line voltage as well as check polarity and ground. I used a male 30 amp plug, a standard 120 volt receptacle tester and a digital voltmeter with a standard plastic electrical box and a standard 120v receptacle. I will use this to test any power source that I plug the R Pod into. Vann
podwerkz
Post Options Quote Reply Posted: 29 Jun 2020 at 4:13pm |
By golly that DIY unit will work, I just use a Camco tester and surge protector. I generally unplug during a storm. Yes I realize stuff can happen, but that has been my strategy for years with a lot of different campers. So far, so good.
Pod_Geek
Senior Member Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 259 |
Post Options Quote Reply Posted: 01 Sep 2020 at 1:05pm |
Second pedestal fault in 6 months detected by Hughes Autoformer
In February the Autoformer indicated a ground fault so I moved sites.
Pulled in to a KOA last Saturday and plugged the Autoformer into the 30-amp socket to check the pedestal before connecting the R-Pod (as always) and it showed an open neutral. 20-amp also showed an open neutral. Walked over to the office and office guy radioed maintenance immediately and by the time I had walked back he had already hooked up a 50-to-30 dogbone to the Autoformer No faults showed up so I just went with it (campground was full of course). Worked fine...no conflagrations resulted I asked maintenance guy if this was a known issue with this pedestal and he said yes He then taped over the 20- and 30-amp sockets with a message that they weren't working and to borrow a 50-to-30 dogbone from the office if needed. Just another cautionary tale from the world of RV electric...
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
Post Options Quote Reply Posted: 01 Sep 2020 at 1:38pm |
I guess if they can’t get away with electrocuting you with an open neutral they’ll happily burn you up by injecting 50A into your 30A circuit. Where is this KOA so I can be sure I never ever stay there?
Pod_Geek
Post Options Quote Reply Posted: 01 Sep 2020 at 1:56pm |
Here's a clue. Let's see if anyone figures it out before I tell you. |
Post Options Quote Reply Posted: 01 Sep 2020 at 2:10pm |
It must be the goats' fault, they like to chew on wire insulation. We used goats to keep down the grass on a solar farm and found that out. Sheep work better.
Luna2020
Newbie Joined: 09 Apr 2021 Online Status: Offline Posts: 1 |
Post Options Quote Reply Posted: 15 Apr 2021 at 9:29am |
OMG...thank you so much for sharing and happy to hear no one was seriously injured. New to TT and had no idea this was an issue. Ordered my tester to have w/ me on all my future trips
