  New Posts New Posts RSS Feed: Anti-Sway bars
Anti-Sway bars - Event Date: 27 Aug 2014 - 31 Aug 2014
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Calendar Event: Anti-Sway bars
    Posted: 07 Nov 2021 at 9:12am
Originally posted by Rpod-Couple
I recommend you stick with a 6000 lb weight distribution hitch. I initially used a 10,000 lb WDH on my Mazda CX9 and R-Pod 171. The CX9 is a similar size vehicle to the Pilot. The 10,000 lb WDH was too stiff and transferred every bump to my CX9. I replaced with 6000 lb spring bars and that smoothed out the ride and kept my front end level.
I haven’t found the need for a sway bar but certainly can’t hurt.
By 6000lb I think you mean a WDH designed for a 600 lb tongue weight. That is on the light side for a mid sized rpod. My 179 had a tongue weight of about 500 lbs. Adding in cargo in the TV it had to lift closer to 700 lbs. The WDH doesn't know whether it's lifing weight on the tongue or in the rear of the TV.
The spring bars are designed to handle about 2x the WDH rating, or 1200 lbs in the case of a 600 lb hitch. It's very common to get 2g bump loads which for me would be in excess of 1400 lbs, too much for a 600 lb hitch.
I had a 1000 lb rated WDH and it did not create too stiff a ride in my Highlander. I do think an 800 lb rated hitch (1600 max rating) would be the best compromise though.
Also you don't want to set up a WDH to level the tow vehicle, just to put the front axle load and height back where it was without the trailer. That results in the tongue weight being added to the rear axle, but no more, so there will still be some squat in the TV rear axle. If that is excessive then you probably have too much stuff in the back of the TV or too high tongue weight.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 1:40pm
Originally posted by Dirt Sifter
Trinity, I just drove south and east from Eureka to Auburn, CA. Once I got down in the valley, the north winds were whipping and passing trucks had me a little concerned at first, but we didn't have a control problem at all. The winds took the top off my propane tank cover, but didn't bother my Rpod 195 while using a friction sway control bar. I was driving the Tundra at the time. While we probably don't need it, we use a WDH as well. Have fun!
Apropos the propane tank cover lid, when you get a replacement, drill a small hole in it that lines up with the holes in the hinge side that are not being used. Use one or more zip-ties through the holes to attach the lid to the cover. For a single tank, one zip-tie should suffice. For a double-tank cover, two zip-ties will be needed. That way, the lid will stay attached to the cover, even if it blows open.
Dirt Sifter View Drop Down
Post Options Post Options   Quote Dirt Sifter Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 4:04pm
Thanks, Stephen, will do. First time in many years of trailering that I've lost one. Winds didn't seem as strong as others we've been in, but that top sure took a powder on this trip.
Greg n Deb 2020 195 HRE
