Anti-Sway bars - Event Date: 27 Aug 2014 - 31 Aug 2014 |
Post Reply | Page 123> |
rickincambridge
Newbie Joined: 22 Aug 2014 Online Status: Offline Posts: 4 |
Calendar Event: Anti-Sway bars Posted: 27 Aug 2014 at 9:00pm |
I've got a 2011 Ford Explorer with a towing package and 6,800 pound towing capacity. Do I need anti-sway bars and a different hitch installed like the R Pod dealer recommended?
rickincambridge
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4507 |
Post Options Quote Reply Posted: 28 Aug 2014 at 5:45am |
You are well within your tow vehicle weight limits. It will really depend on your towing experience and comfort level.
Happy Podding!!
HuronSailor
Post Options Quote Reply Posted: 28 Aug 2014 at 9:27am |
Yes, you will be fine.
We're planning a trip to the west coast, and some friends and fellow podders who've made that trip suggested that due to potential high crosswinds we might want to add a single sway bar before crossing the mountain ranges between there and Michigan. Cost for the sway bar and hitch adapter plate was $70 delivered from eTrailer. We've never had any serious issues with a simple bumper hitch, but after installing the sway bar, the wiggle we got in the occasional crosswind or when being passed by a semi has been eliminated. So depending on where you plan to tow, this may be something you want to consider. With your vehicle a weight distribution hitch shouldn't be needed. I don't have one on my pickup.
Newsguy12
Groupie Joined: 30 Mar 2014 Location: Nathrop, CO Online Status: Offline Posts: 54 |
Post Options Quote Reply Posted: 28 Aug 2014 at 11:28am |
I'm towing our 179 with a 2014 Jeep Cherokee with a 4500lb tow rating. No need for weight distribution hitch due to low tongue weight. Installed an anti-sway bar...and I have yet to feel any wiggle even when passing a semi. We just towed it across I-70 from Cincinnati to the Rocky Mountains. My favorite quote is from my wife...."Is it still back there?"
Ram 1500
5.7L V-8 Hemi 2015 R-Pod 179 |
Outbound
Post Options Quote Reply Posted: 28 Aug 2014 at 1:56pm |
Need anti-sway? No. I towed my r-pod for almost 2 years without a sway bar. However, after one particularly long, gusty/windy drive with the trailer fishtailing behind me, I decided that a sway bar might be a good idea. It really was; I now won't go without anti-sway. Honestly, it does make driving much more relaxed.
Now, weight distribution may be a different story. Check the spec on your r-pod (different models have different tongue weights) and on your truck (you are aware that tongue weight and tow capacity are different things, right?). If you're close (or over), definitely get a WDH.
Post Options Quote Reply Posted: 28 Aug 2014 at 8:52pm |
My story is the same as Outbound's - about 2 years w/o anything until one very windy day. At the time I had a Sienna so I took care of 2 problems and got a WDH that includes sway control. A world of difference in ride quality with the WDH acting as an additional suspension system. When I moved to my current TV I tried half a trip w/o and half a trip with my WDH and have always used it since. Still rides better with it.
Trinityfly
Newbie Joined: 29 Sep 2014 Location: Northern Calif Online Status: Offline Posts: 11 |
Post Options Quote Reply Posted: 18 Oct 2014 at 1:36pm |
Just picked up my 179 and drove it the 50 miles home. Dealer said I wouldn't need weight distrubution or anti sway. After reading the above info I am def thinking about getting anti sway. Advice would be welcome
Tow vehicle is a 2011 Toyota Tundra 4.6 V8 with factory tow package What do you all think? How much should I pay? Thanks in advance |
Joe and Diane, pups Jenny and Tyke. RPod named Lilly.
Alive and well deep in the toolies of Norther Calif |
Outbound
Post Options Quote Reply Posted: 18 Oct 2014 at 2:31pm |
I've got a Husky friction sway bar. http://www.huskytow.com/product/sway-control/ . But there's one from Reese thats essentially the same.
Purchased it from my local dealer (Campkins in Whitby) for about $80. Most any dealer who sells small trailers (e.g. popup/tent trailers) will carry them. The install was reasonably simple: I had to drill 6 holes in my trailer tongue for self-tapping screws - I recommend a titanium bit to make it easier. Also, I had to have a metal tab (included with the sway bar) welded to my hitch - which my dealer was able to do for $20 cash. Note that friction bars are left-sided or right-sided, so make sure you have the tab welded (and drill those mounting holes) on the correct side. |
Budward
Senior Member Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Post Options Quote Reply Posted: 18 Oct 2014 at 5:20pm |
Here is the one I use- it is on sale for $29.99 (normally $34.99) and if you look you can find a 20% off coupon pretty easily.
It is universal- can be mounted left or right. http://www.harborfreight.com/trailer-sway-control-kit-96462.html |
2014 179
NormanHill
Groupie Joined: 30 Mar 2014 Online Status: Offline Posts: 49 |
Post Options Quote Reply Posted: 27 Oct 2014 at 9:46pm |
Get the sway control. One side should be fine for the pod. The need for a WD hitch depends on how big your vehicle is compared to the trailer. My F150 didn't need WD, but after experiencing some sway from these single axle trailers I'm now a believer in adding it.
