Page <1234> |
jeeperic ![]() Groupie ![]() Joined: 27 Aug 2014 Location: Alberta, Canada Online Status: Offline Posts: 48 |
![]() Posted: 17 Sep 2014 at 12:12pm |
Oh? It's the one that came with the Pod. Would you suggest two new ones, then come spring?
That's the power button..press it. Turn it all off. Go outside! '14 RPod 171 '09 Jeep Wrangler JK (mine) '14 Dodge Ram 1500 4x4 (hers) |
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Yes they should be matched if you are going to parallel them.
But- in past times when I often literally couldn't afford two NEW batteries to match I'd have two of any vintage and capacity....run one until low then switch to the other one. That works fine, and is just a minor annoyance in the middle of the night when the switch is always needed. I forget which number Murphy's Law that is
2014 179
Towed by a 2015 Ford Transit Diesel Supervised by a German/Aussie mix and a Labradoodle! |
Although one of the biggest advantages of running two in parallel (or series if they are 6 volt) is you actually get more total amps out from the 2 than you do by running 1 and then switching to the other.
So for two 110 amp batteries, where you can get 55 amps each (50% SOC) if you run them seperately, you get 110 amps total. Run them together and you'll get around 125 amps before hitting 50% SOC.
Yep - sounds about right... Murphy can be a sneaky bugger!
For a winter project I'll be building a storage box for the front which will house the batteries and perhaps a compartment for a water filtration system as seen elsewhere on this forum. Who knows, maybe even put the propane tank in there somehow!! |
Just be sure you have vents in the bottom to drain off any propane leak that might happen.
2014 179
Hi jeeperic,
I couldn't be happier with my battery install. Remember that 6 v. CG batteries are taller than 12v. and won't fit in a standard battery case. Following someone else lead here (sorry, I forgot who to give credit to), I simply cut a couple of 12v. boxes and extended them with some plastic and gorilla tape. Cheap, easy and has held up well. You can see the batteries and install by clicking the link in my sig below. fred
Again, good advice.
I just did some measuring, and there might be room for a second propane bottle. With the added tongue weight, though, I won't be towing with the Jeep anymore. My wife might actually let me drive her new pickup. ![]() I like the clean look of this: ![]() -I'll need a pigtail with changeover lever -bidirectional regulator -another length of hose as an afterthought...try this scenario: six days camping, two adults = two hot showers daily, supper everyday on the stove, furnace on at night, and regular dish washing in the sink with hot water, etc, etc. Do I really need two tanks?? |
Fred:
I'm going to print off all those mods you've done! Absolutely inspiring. |
Thanks jeeperic.
I would give some thought to that dual propane install unless you plan on doing a lot of extended camping without possibility of refill or backup. One 20# tank goes a long way. Further than you might think even with furnace, fridge and stove. A couple of things I didn't yet add to the mod-pics which we never leave home without is my Weber Q and a 1 gallon propane tank for the Q and/or in case we happen to run out of the one 20# on a cold night.
Have fun! fred |
I think you're right. I'll hold off on the second tank for now, heck, we've only had the Pod out once! That'll free up space in the box for other things...
By the way, do you have the stain color handy for your trim? It matches perfectly? |
Page <1234> |
