  New Posts New Posts RSS Feed: Hi, potential R-Pod owner but...
Topic ClosedHi, potential R-Pod owner but...
SiberD View Drop Down
Direct Link To This Post Topic: Hi, potential R-Pod owner but...
    Posted: 29 Oct 2014 at 6:35pm
Originally posted by Luv2Q
Congrats!  .. on both the Tundra as well as the 179.  You should be ready to rock 'n roll!
Thank you. We're looking forward to some good memories traveling in the Pod. My wife is afraid of flying and with us approaching retirement age, I'm already semi-retired, in order to see what she wants to see requires something like the Pod.
Luv2Q View Drop Down
Direct Link To This Post Posted: 29 Oct 2014 at 4:23pm
John & Teri
Tundra 5.7L V8 / RP 180
Direct Link To This Post Posted: 29 Oct 2014 at 1:34pm
Welllll, pulled the trigger on a new 2014 model 179! Will be picking it up the second week of Novembe. The bigger kitchen area along with a ton more storage space inside swayed me from getting a 177 Smile
Direct Link To This Post Posted: 12 Oct 2014 at 6:22pm
That will do it.
Direct Link To This Post Posted: 11 Oct 2014 at 6:47pm
Ok, I couldn't find a F150 at a reasonable price and I'm impulsive so instead I bought a 2001 Toyota Tundra SR5 that has a 4.7L V8, 128 in wheel base, and best of all, only 88,000 miles on it!
Time to start looking for an Rpod Big smile
Direct Link To This Post Posted: 08 Oct 2014 at 1:16pm
That will be a great present  - for him, and you!
Direct Link To This Post Posted: 08 Oct 2014 at 11:30am
Well, I've decided against doing this for now. I talked to the place that put my hitch and wiring on for my small landscape trailer. I explained what I wanted to do giving him the specs on both the Tribute and the R-pod and he recommended not doing it.
I just may give the Tribute to my Son who is graduating college in May and go get a used F-150 with a V8 Big smile
Direct Link To This Post Posted: 07 Oct 2014 at 8:28pm
Welcome.  I started off with a similar vehicle - about the same wheel base and HP.  It was fine for trips on back roads, and most highway trips, but its limits were evident in bad conditions.  Before tackling the Rockies I moved up.
Direct Link To This Post Posted: 07 Oct 2014 at 4:30pm
Thanks for the input. Where did you find room for the transmission cooler???  I don't see any room up front.
Outbound View Drop Down
Direct Link To This Post Posted: 07 Oct 2014 at 2:50pm
Well, I've got a 2008 Tribute - 3.0L 2WD and I've been using it to tow my r-pod for the past 5 years.
I run full synthetic oil, synthetic transmission fluid and have an add-on transmission cooler (which was surprisingly inexpensive).  At the end of the season, the tranny fluid is pitch black and I change it.
Frankly, I don't recommend the setup and I'm definitely pushing the limits.  The Tribute is underpowered to pull my 2100 pound RP-171 (2600 pounds loaded).  I tend to limit travel to 55mph, which keeps the RPMs about 2500 and the transmission fluid temperature below 220C.  It'll go 65, but its definitely a short-term effort for passing only.
