elastic netting over slide opening |
Post Reply | Page <1234> |
Luv2Q
Senior Member Joined: 30 Aug 2014 Location: Central TX Online Status: Offline Posts: 309 |
Topic: elastic netting over slide opening Posted: 17 Nov 2014 at 7:34pm |
Just one final thought which may be of interest to the OP (& maybe others). Here's a site that has netting (& has been mentioned before):
John & Teri
Tundra 5.7L V8 / RP 180 E2 WDH / Integrated controller (POS) replaced by Tekonsha P3 |
Posted: 17 Nov 2014 at 5:52pm |
This is a "wish list" item, so it really doesn't matter who likes the suggestion or not except Forest River. The point of this sub-forum is to present ideas to FR that will make things better or easier for pod owners (and in this case it sounds like other RVs have the same problem). We know FR comes here, and we know some suggestions made here have made it into production, so it works.
Multiple members have come down on both sides of this issue, both sides have valid solutions. Discussion is great. But let's end this discussion before feelings get hurt and bad things happen. We've never locked a thread, let's not start now. |
Posted: 17 Nov 2014 at 2:52pm |
"judgmental and condescending"?? Really? Crossing boundaries based on seniority?? At what point did I say you, or ANYONE else didn't know anything because they just got their Pod, or just joined the forum? In what way is it NOT "common sense" to NOT put things into the path of moving devices, and or to check the area is clear before initiating said move? |
Posted: 17 Nov 2014 at 9:45am |
Let's not go off the deep end. 99% of the conversations over the years here have been civil.
If you read my post, I agreed with you and Podster that this isn't a normal issue with most slides. It looks like enclosing that area on both sides would solve it.
1945gypsy
Newbie Joined: 09 Nov 2014 Location: United States Online Status: Offline Posts: 7 |
Posted: 17 Nov 2014 at 9:33am |
No, not well put. His was judgmental and condescending, totally. Just rude. Without knowing circumstances, you are crossing boundaries under the guise of seniority. Common sense, eh? Where's yours?
RL
Podster
Posted: 17 Nov 2014 at 8:55am |
Here are some pics of the slide closed...It does create quite a void. Even if netting was used something could still work it way back there and cause trouble. |
Cliff & Raelynn
Luv2Q
Posted: 14 Nov 2014 at 11:37pm |
Seems like it should work. You might also look at a cloth store for elastic panels or tape. Seems like I've seen it in 6" or 8" widths.
John & Teri
Podster
Posted: 13 Nov 2014 at 7:41pm |
I'm going to cover my POD this weekend, I'll take a pic of the slide closed and post it here....
Cliff & Raelynn
Posted: 13 Nov 2014 at 7:29pm |
This wouldn't be a problem for most slides, which have solid sides. It sounds like this design exposes a hole that is hard to clear. I wouldn't want to get on my stomach with a flashlight every time I wanted to open the slide. I don't need to do that with the slide on my Salem - I make sure I have enough room outside and then I push the button.
I'm curious how this caused the counter to crack.
Sleepless
Senior Member Joined: 07 Jun 2013 Location: Titusville, FL Online Status: Offline Posts: 556 |
Posted: 12 Nov 2014 at 8:28pm |
Very well put, furpod. I have had power slides for over 20 years without a problem. I did close a car door on my fingers once, though.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche |
