Air conditioning |
Post Reply | Page 123 5> |
Topic: Air conditioning Posted: 13 Sep 2015 at 3:21pm |
I think in a lot of cases it is cheaper to ship the whole thing back and repair it at the factory. I had a transmission with a bad solenoid on my prior minivan, replaced under warranty. They replaced the whole thing.
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1216 |
Posted: 12 Sep 2015 at 3:02pm |
What surprised me is they replaced them instead of repairing. Must be the cost of labor and parts in that it was less money to replace.
Posted: 10 Sep 2015 at 9:30pm |
Ouch, and good that it was all caught under the warranty. You do NOT want to replace either of those things on your own. You'll be good to go for another 100,000 miles.
David and Danette
Posted: 10 Sep 2015 at 5:41pm |
I have good news with our AC, its being replaced under warranty and not only AC but the refrigerator too. When I took the AC in to be checked out I mentioned the refrigerator did not seem to be working properly, I was recommended to have it checked too since the warranty would be over in November. Thankful I listened to the good advice because the refrigerator was leaking ammonia. Within the past 12 months the axle which included the tires ,wheels with brakes were all replaced and now AC and refrigerator. It's almost like having a new camper even though it is a 2012.
Posted: 31 Aug 2015 at 8:03pm |
I agree that doesn't sound right, glad you are covered.
David and Danette
Posted: 29 Aug 2015 at 3:18pm |
I think that there may be a problem with AC, according to the surge protector the AC is using 15 to 16 amps. while operating and the compressor cycles on and off about every 5 minutes. It is still within the 2 year warranty I think I will have Camping World look at it. " I just got off the phone with Camping World and explained the problems and they said it is not operating normally and was told it should only be using 12.5 amps. and the compressor cycling on and off every 5 minutes is not normal. It will be covered under warranty and will bring it in Tuesday morning." Thank you, for the help
Posted: 26 Aug 2015 at 7:10pm |
It could be an indicator of a problem, but usually if something is wrong electrically you'll trip a breaker or the problem part will be hot. I've never installed a hard-start cap so I can't comment on that specifically. I would try it on a 15 amp outlet again to be sure it is failing like it did before, then reconnect the cap and run your test again. If it solves the problem I would close it up and go camping.
David and Danette
Posted: 25 Aug 2015 at 8:14pm |
Posted: 25 Aug 2015 at 7:52pm |
Too warm, like you couldn't touch it?
David and Danette
Posted: 25 Aug 2015 at 1:07pm |
I went to amazon.com and got the instructions and connected everything the correct way but the capacitor what I thought was getting to warm so I disconnected it. I decided to leave it alone and if the AC stops working I will take it to a AC repairman. I will stick to woodworking, electricity I don't know that much about.
