  New Posts New Posts RSS Feed: hot water bypass valve on 171
1tulip View Drop Down
Post Options Post Options   Quote 1tulip Quote  Post ReplyReply Direct Link To This Post Topic: hot water bypass valve on 171
    Posted: 28 Mar 2015 at 2:39pm
OK.  I give up.  Where is the hotwater bypass valve?  You know... there should be a red hose, blue hose, and in-between another hose and valve that bypasses the hot water heater?  I can't find that anywhere.
kymooses View Drop Down
Post Options Post Options   Quote kymooses Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2015 at 3:19pm
Those valves will be right directly past your water heater, have you lifted up your bed and panels beneath it to access your water heater already?
Post Options Post Options   Quote 1tulip Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2015 at 6:35pm
Yep.  Thanks.  Seems they are in different places in different models.
Post Options Post Options   Quote furpod Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2015 at 6:45pm
They are ALL, right behind the water heater.. but the water heater is in different places based on floor plan.
Signature removed, so as not to trigger any non Ford owners, non Irish Setter owners, current R-Pod owners, unhandy or mod negative Pod owners, or single campers of any gender.
