toilet paper in the wet bath?? - Event Date: 01 May 2015 - 30 May 2015 |
JohnBG
Senior Member Joined: 14 Apr 2015 Location: Deltona, FL Online Status: Offline Posts: 190 |
Calendar Event: toilet paper in the wet bath?? Posted: 21 Jun 2015 at 9:13am |
Simple idea: http://gurutotheoutdoors.com/dry-toilet-paper/
2010 R-Pod RP-171
2010 Honda Ridgeline TV |
Plantguy
Senior Member Joined: 29 Mar 2015 Location: Calistoga, Ca Online Status: Offline Posts: 102 |
Posted: 20 Jun 2015 at 10:56pm |
Won't the MARINE PAPER HOLDER STICK INTO THE PANTRY ON A 179?
Life is too important to be taken seriously!i
TigerPawd
Groupie Joined: 04 Feb 2015 Location: Corpus Christi Online Status: Offline Posts: 68 |
Posted: 03 May 2015 at 2:49pm |
There is a fair amount of room up under the basin. We got a "one arm" paper holder and stuck it up in the empty area. So far it's worked OK, but we keep the shower water flow low. We also keep an old shower cap ready in case water splashes get to be a problem.
Changing rolls with this type of holder is easy, even though it's in a crowded area. |
Joan, Jerry and the two Pugs
2015 R-Pod 179 |
Travelcottage
Newbie Joined: 23 Apr 2015 Location: Florida Online Status: Offline Posts: 30 |
Posted: 03 May 2015 at 1:51pm |
I just purchased a toilet paper holder that has cover on Amazon for $15 ....waiting for it to arrive.
Cheri
Posted: 02 May 2015 at 8:30pm |
I went the cheap route and bent a length of copper wire so it would hook over the two valves, and stuck the roll on there (and hung a trash bag from it). When it was time to shower I would unhook it and take it out.
Redwing3
Newbie Joined: 18 Mar 2015 Online Status: Offline Posts: 6 |
Posted: 01 May 2015 at 10:49pm |
Wow! I like the Marine roller... Just converting from a sailboat! There must be space for the rear of the dispenser to not project into the sleeping area? Squashing the roll seems an alternative but then the paper Will not roll off well! Hah! It is a wonder the Forest River people did not come up with the marine roller solution... They must carry their roll in each time. Or have they ever used the Loo in the RPOD? Designers should be made to use the RPOD for a period of time while designing.. Not just look at computer layouts!
Outbound
Posted: 01 May 2015 at 10:47pm |
I bought a toilet paper holder that is held to the wall with 3M tape. I located it high on the rear wall, just above my left shoulder (when sitting on the toilet). When the shower curtain is closed, its well protected from the water.
ToolmanJohn
Posted: 01 May 2015 at 10:37pm |
I smash the roll as flat as possible and stuff it into he magazine pockets. I remove it before taking a shower . Forgot once, and it was a soggy mess.
M0tl3y
Groupie Joined: 21 Sep 2014 Location: Utah Online Status: Offline Posts: 61 |
Posted: 01 May 2015 at 8:43pm |
I installed this marine TP holder that closes up and keeps it dry as well as stopping it from unrolling during travel.
The 178 club
Redwing3
Posted: 01 May 2015 at 7:10pm |
No one it seems has addressed the issue of where to place a roll of toilet paper for use in the
wet bath. Now I know you are all going to have the issue at some point right? So you just take the paper in when you think you need it? There is no shelf near the door outside the Loo in the 2015 178. Or Do you... (TMI alert here!) use the shower head as a bidet? I am looking for solutions before heading out on my first "shake" down event!
