  New Posts New Posts RSS Feed: Manual override of slide
Topic ClosedManual override of slide - Event Date: 22 Jun 2015
Podster View Drop Down
Direct Link To This Post Calendar Event: Manual override of slide
    Posted: 12 Jul 2015 at 8:03am
Originally posted by Leo B
Remember once you disconnect the electric motor, you need to brace it shut, to keep it closed.
Pretty sure that is on the Schwintech slide only.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 12 Jul 2015 at 7:23am
Direct Link To This Post Posted: 12 Jul 2015 at 7:20am
Originally posted by Band Leader
I was told that the manual override, crank nut was below the stove in my new R Pod 178. Do I have to remove the panel to get to it? I can see a black metal box surface in the space below the slide, but no nut. This is just in case I need to manually move the slide in some day.
Yes, you have to remove the panel inside the POD under the stove near the floor, 4 screws. It's not a schwintech slide, its the Lippert over the floor slide. The crank wrench will fit it, and you are suppose to dis-connect the electrical on the motor to prevent back flow current.
Cliff & Raelynn
Ranger 4.0/178
hammockmadness View Drop Down
Direct Link To This Post Posted: 10 Jul 2015 at 8:30am
If you have a Schwintek slide, I attached a video from Lippert that shows how to elecronically override the slide and mechanically override it.  I'm not sure if R-Pods have a controller that is easily accessable.  A Schwintek slide is the one that has an aluminum gear bar at the top and bottom of your slide.  There also some videos from Lippert that show how to lubricate the internal gear assembly behind the slide wipe seal.....
http://youtu.be/xojUdPDWNS0
Band Leader View Drop Down
Direct Link To This Post Posted: 22 Jun 2015 at 11:27am
2016 R Pod 178
2001 Ford F 150 Triton V8
Kayaks and old folks bicycles
