Please read & check your hitches |
Post Reply | Page <12345> |
mccvii
Newbie Joined: 20 Apr 2015 Location: Georgetown, tx Online Status: Offline Posts: 10 |
Topic: Please read & check your hitches Posted: 17 Aug 2015 at 11:22am |
No I didn't. The hitch fell over the ball and the latch locked. Its honestly never occurred to me to raise the jackstand to ensure proper connection. The hitch was (at least in appearance) fully over the ball and locked.
I've reached out to Forrest River via email but I have not yet received a response. In the meantime, I am having the hitch inspected by a local trailer shop / service center that performs state safety inspections. Thankfully, the shop is about 1/4 mile from where I store my trailer. I appreciate the tip to raise the jack to verify static mating. I've never done that before but maybe I've just been lucky with my previous trailers. Hoping to hear from FR this week.
2013 178
2015 Nissan Pathfinder |
leahfoo
Newbie Joined: 19 May 2015 Location: cape cod Online Status: Offline Posts: 22 |
Posted: 17 Aug 2015 at 12:06pm |
Stiff lock fixed with WD 40.
leahfoo
leahfoo
Posted: 17 Aug 2015 at 12:26pm |
WD 40 hitch latch.
leahfoo
samiam2
Newbie Joined: 16 Oct 2014 Location: Texas Online Status: Offline Posts: 23 |
Posted: 17 Aug 2015 at 1:42pm |
Sorry for the delay guys.
Forest River agreed to change my coupler out with the "SAME" crappy coupler. I turned them down! I don't feel they have safety or people's life a high priority. They are a bottom line/cut cost/out source parts cheap company. Example: Steel from China - has a lot of impurities and is weak, but looks just like USA steel. I want to feel safe driving down the road. I want to sleep at night knowing my trailer didn't come off, kill anyone, or me! I had custom trailer and hitch place inspect and replace hitch with a bull dog hitch for $150. Ask yourself. Is it worth having Forest River replace with same cheap, faulty coupler or $150 worth knowing you can drive down the road safely! P.S. YES, I did file a complaint (attached link to this forum) with: http://www.fhwa.dot.gov/ U.S. Department of Transportation Federal Highway Administration. (I also file about their axles.) If enough people email the U.S. Department of Transportation Federal Highway Administration. They will investigate! See picture of new couple. uploads/3317/20150721_130702.jpg
mccvii
Posted: 20 Aug 2015 at 3:25pm |
Thanks for the info Samiam. I went to my local dealer and I didn't see any pods with the new hitch design from your photos. The one's I checked appeared identical to what is on mine. I have not heard back from Forest River on this but I'm kind of inclined to follow your lead. Its a small price to pay for the security. Plus, it was already going to cost me $100 to rebuild the coupler with new parts and another $100 to install a new jack and safety chains.
Definitely going to issue a complaint to DOT. FR needs to tell us if there is a problem with the hitch/latch. Jacking the trailer up to verify solid coupling is a good preventative step but it can't overcome faulty engineering - if that proves to be the case. At any rate - this wasn't a cheap lesson to learn but it could have been a hell of a lot worse had the hitch decouple at 60 vs. 25. If I end up hearing back from FR, I'll post.
2013 178
Camper Bob
podders Helping podders - pHp Joined: 26 Sep 2011 Location: Portland Oregon Online Status: Offline Posts: 913 |
Posted: 20 Aug 2015 at 4:00pm |
Great info. Just called U-Haul to see about a replacement coupler. In this state, you must use a "Certified Welder," and they referred me to one. His quote to remove and install a better coupler was approx. $165. Cheap for the piece of mind. For those who might want to do it themselves, they might think twice before tackling this project. Not sure all what a "Certified Welder" qualifications are, but I would suggest, that it is certainly a safety concern. If you are going to replace your coupler, might do some investigation before plunging ahead. Safe Travels.
Camper Bob and Camper Sue
samiam2
Posted: 20 Aug 2015 at 4:38pm |
mccvii and Camper Bob,
I had a custom trailer & hitch company install the Bull Dog hitch I posted. Forest River "WILL NOT" replace coupler with a different one. They will "ONLY" replace with same coupler on trailer. Welding certification come in many positions, metal thickness, welding process, and metal types. When the term "Certified Welder" is used it only means that welder is certified under the welding procedure that have tested under. There is not a single welding certification that covers all types of welding. All welding certifications come in many positions. The position are different depending if the welder will be welding on plate of pipe. The terms properly used in the welding field refers to plate as "structural welding" and pipe as "pipe welding". I'm a welding inspector for American Welding Society for oil rigs, for the last 15yrs. Thanks, Sam
Camper Bob
Posted: 20 Aug 2015 at 5:15pm |
I never am ceased to be amazed at the expertise that we have on this forum. I am well out of warranty so would be doing this on my own. Since FR will only replace like with like, I guess it is up to the Pod owner to belly up to the bar if he or she wishes to replace the supplied coupler with one that is more secure. Just wanted to alert the other Podders of the importance of using a welder that is licensed to replace the coupler. Thanks for the alert. Safe Travels.
Happy Tripping
Posted: 21 Aug 2015 at 9:51pm |
There seems to be 2 separate 'issues' here.
1. False hitches - Happened to me, my bad, prevented by watching the TV rise up. 2. Inadequate/weak hitches. R-Pods are light, I doubt if a heavy duty hitch is required, but people describe their hitches as taking a beating. Is this 'operator error' - chronically driving too fast on bumpy roads, or something else?? I have no complaint about the durability of my 171 hitch so far, and I've gone cross country. |
Posted: 22 Aug 2015 at 8:30am |
I wonder too. My five year old 177's hitch looks like new. I think it is something that needs to be looked at as regular maintenance, but unless damage is found I wouldn't jump to replacing it.
