TV-Pod electrical connection |
Kobwo
Newbie Joined: 05 Sep 2015 Location: Nation of Texas Online Status: Offline Posts: 12 |
Topic: TV-Pod electrical connection Posted: 29 Sep 2015 at 9:19pm |
Hello,
I have a 2015 Silverado and based on another post on this forum, I went out and tested the pins on my 7 pin connector. The + & - have a constant 12v even with the truck turned off. So, I assume that means that when we reach our destination I need to disconnect the trailer to isolate the TV battery, correct? Thanks
Shawn, Mohyon, and Chewy
2016 Rpod 180 On Order : 2015 Silverado-Texas Edition |
Podster
Posted: 29 Sep 2015 at 9:39pm |
Yes Sir, if it is not switched, but always a good idea to disconnect when camped, but not necessary for short stops for quick shopping or a quick lunch.
Cliff & Raelynn
Kobwo
Posted: 29 Sep 2015 at 10:10pm |
Got it, thanks for the reply! Hopefully I won't forget.
Thanks
Posted: 30 Sep 2015 at 2:12pm |
Only things I can add is, if you are camping with hookups then don't worry about it. The converter will just top off the TV battery going the other direction.
Kobwo
Posted: 30 Sep 2015 at 2:54pm |
Great to know
Podster
Posted: 30 Sep 2015 at 8:30pm |
Unless you are away and have a power failure...
Cliff & Raelynn
