sway bars |
Post Reply | Page 12> |
jswann
Newbie Joined: 06 Dec 2015 Location: Warren VT Online Status: Offline Posts: 9 |
Topic: sway bars Posted: 26 Jan 2016 at 6:28am |
What are thoughts on sway- bars ? Needed or No need ?
Happy Tripping
Posted: 26 Jan 2016 at 7:24am |
Try an 'Advanced Search' for "sway bars". You'll get more than you want on this.
My 2 cents - If you have a heavy and powerful 'capable' tow vehicle, with R-Pods you don't need them, if you have a marginal tow vehicle, you absolutely need them, and if you are in between, .... well, that's where the arguments start. Do the search and make up your own mind.
jswann
Posted: 26 Jan 2016 at 9:37am |
Thanks for the info I have seen several forums on small campers about this .
I have a 2015 R Pod 178 I will be pulling it with a 2012 Nissan Pathfinder V - 6 6,000 lb towing capacity with air bag rear suspension added. Pulled it home with 3/4 ton Chevy and did not know it was even back there . But plan to use pathfinder to pull with. |
Outbound
Posted: 26 Jan 2016 at 9:56am |
For the first two years, I didn't have anti-sway and I really didn't think I needed it. The trailer was just fine; sure, there was the odd sway, and I'd get some movement while passing tractor trailers, but it was nothing that concerned me.
Then, on a short three-hour trip, we ran into constant strong, gusty winds. It was nothing out-of-control, but it was an exhausting drive and my shoulder muscles were cramped the entire weekend. I was also told that the ride from the passenger seat was unpleasant and that we should never travel in conditions like that again. After we got back home, I popped into my RV dealer and bought a simple friction anti-sway bar for somewhere in the $60-$80 range and installed it myself in about an hour. That simple anti-sway bar has made a tremendous difference in drive comfort and I highly recommend installing one.
jswann
Posted: 26 Jan 2016 at 10:19am |
Thanks Craig it sounds like a smart move .
I think I will get one it sure can't hurt. I pull much larger trailers a lot with excavator and loader but that is so much easier then a single axel camper 😜. Jeff |
Posted: 26 Jan 2016 at 1:26pm |
I got the Equalizer 4-way sway control hitch when we bought our R-Pod. We are towing with a 2016 Ford Escape with factory tow package. I did not try towing without the Equalizer, and after our recent trip, I don't want to even try it. Even with our smaller vehicle, the R-Pod towed well and only when we had very high crosswinds did I notice any problems. I am sure that without the sway control (both that of the hitch and that of the vehicle's systems), we would have had major problems.
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Online Posts: 3223 |
Posted: 26 Jan 2016 at 6:01pm |
100% agreement with the above posts. When we picked up our 177 in March of 2011 we had significant snow on the roadbed and didn't think the sway bar was necessary. However, the first time we towed on dry roads with any crosswind we had problems above 45 mph with our Explorer. Once that was installed, no problems, even with significant cross winds.
codycountry
Senior Member Joined: 26 Jan 2014 Location: Wyo Online Status: Offline Posts: 168 |
Posted: 26 Jan 2016 at 6:40pm |
I agree with Outbound. I went a couple years without a stabilizer, even when pulling on snow and ice I made it OK, and high winds are the norm here in Wyo where we live so I have had some interesting trips with full rudder. I pull with a F250 super duty super cab v10, so I have a lot of mass, length of truck, and a lot of horses available, but when I bought the friction anti-sway from Amazon for about sixty bucks, it was a noticeable improvement and now the pod really never wiggles back there. I also have the hitch a little bit below level nose down a slight touch, that helps some too with my rig. 177HRE. I always leave home with a full water tank. Anti sway: Better to have it and not need it than the other way around. IMO. Safe travels.
Posted: 27 Jan 2016 at 7:50pm |
Same as Outbound. Except I decided to get a WDH which included sway control to take care of 2 problems.
jswann
Posted: 28 Jan 2016 at 6:57am |
You use WDH with a large TV ? Are you pulling with a full size Tahoe ?
