  New Posts New Posts RSS Feed: electrical outlets
Topic Closedelectrical outlets
rayman View Drop Down
Direct Link To This Post Topic: electrical outlets
    Posted: 25 Feb 2016 at 8:15pm
Just took my 2016   179 out of winter storage.None of my interior or exterior outlets nor my vent fan have power.Everything else works.It's too late and dark to check now but would all these be on the same circuit? could it be a breaker tripprd or a fuse blown? Anybody have any ideas?
ky.froggers
Podster View Drop Down
Direct Link To This Post Posted: 25 Feb 2016 at 8:31pm
Nope, 120v (AC) outlets are hot only if plugged into shore power.
The vent fan in the bathroom is on the 12v (DC) circuit. So are the lights, Heater Fan, Water Pump, and Fridge, HWH, and Heater Controls.
Now that said, the POD on board batter charger / converter will supply 12v to the system when plugged into shore power.
2 questions for you:
1. What is the status of your 12v battery?
2. Did you leave the battery on the POD connected during long term storage?
3. When you tried your fan today and the plugs...did you have the POD plugged into shore power?
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 25 Feb 2016 at 8:39pm
When i stored it i took the battery off and kept it hooked to a small charger.When i checked the power i had it connected to shore power.
ky.froggers
Direct Link To This Post Posted: 25 Feb 2016 at 8:45pm
OK, well did you reconnect the battery? Red to + and while to - ? If this was even reversed for a split second it's like the two 40amp fuses that protect against reverse polarity are blown.
But that doesn't explain why the 120v plugs didn't work. One of the outlets is a GFI so check that and reset it if it needs it.
If you did not reconnect the battery, keep in mind that the POD battery leads are hot when plugged in to shore power and if they are shorting, that can cause problems.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 25 Feb 2016 at 8:49pm
I did reconnect the battery and i'm pretty sure they were connected the right way.i guess i'll just dig into it tomorrow.
ky.froggers
Direct Link To This Post Posted: 25 Feb 2016 at 8:51pm
It sounds to me like your shore power is not getting into your POD, if everything checks out on the POD it maybe a bad extension cord or a tripped house breaker. Double check that because your systems suggest no shore power feeding and a dead 12v battery.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 25 Feb 2016 at 8:56pm
Thanks Podster.I'll run through all the possibles tomorrow.My son is an electrician and i may get him tom take a look.Thanks for your input!
ky.froggers
Direct Link To This Post Posted: 25 Feb 2016 at 9:04pm
Oh good, nice to have an electrician in the family. Good luck and please report back and let us know the outcome so we can learn from it as well. Good luck!
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 25 Feb 2016 at 9:12pm
Oh and by chance, have you recently had a new 30amp plug wired into your house wiring for the POD?
I ask because we have had several Podders hire a certified electrician to do this only to damage the POD electrics because of an error with 220v to the new plug. The reason is that Dryer 220v plugs look very similar to RV 30 amp 120v plugs and some electricians are not familiar with the difference.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 26 Feb 2016 at 9:49am
Got it fixed Podster.I sent you a personal message.
ky.froggers
