No Complaints! |
Post Reply | Page 12> |
par49
Newbie Joined: 20 Aug 2016 Location: KS Online Status: Offline Posts: 15 |
Topic: No Complaints! Posted: 20 Aug 2016 at 10:25pm |
Glad to hear you have had no problems. It will remain to be seen on the newer 2016 models. Thanks for the input.
par
Posted: 04 May 2016 at 9:06pm |
Not sure if you need white or off-white, but here you go:
Stevecheuv
Newbie Joined: 24 Apr 2016 Online Status: Offline Posts: 5 |
Posted: 03 May 2016 at 7:45pm |
I have a 2011 172 and my wife lost the water heater cover on outside of camper. What are dimensions of a replacement
Posted: 31 Mar 2016 at 11:14am |
There are lots more good outcomes than bad ones. Sadly the few that have problems include a few that prefer to whine instead if working with their dealer. They post endlessly on the internet and give false impressions to others about quality.
Leo B
Posted: 30 Mar 2016 at 8:47pm |
Good to hear!
Hi-Line
Newbie Joined: 11 Jun 2015 Online Status: Offline Posts: 24 |
Posted: 30 Mar 2016 at 8:32pm |
Glad to see at least some happy campers! I got my 2016 179 last summer from a high-volume, reputable dealer and have had no problems...knock on wood...but I've only used it about 2 weeks to date, towed it approx. 2,000 miles with a Toyota Tundra. I love the camper!
RVCouple
Newbie Joined: 15 Nov 2015 Location: Alabama Online Status: Offline Posts: 21 |
Posted: 30 Mar 2016 at 5:25pm |
Just to update my earlier post. After another lukewarm shower, I did crawl up under the bed and turned the bypass valve. Now my water is hot enough to scald you. The hard part was getting those tiny screws loose. I used Velcro strips to fasten the cover back so it should be easy to remove when I need to winterize.
2016 R-Pod 179
RVCouple
Posted: 13 Mar 2016 at 11:14am |
I've been planning to check the valves but haven't wanted to crawl up under the bed yet. The rpod is still in the campground. Will probably do so when we bring it back home.
2016 R-Pod 179
Posted: 12 Mar 2016 at 3:27pm |
Good point Charlie. If one follows your advice they will find that the 130 degree water is HOT enough for any ones liking. Since we normally dry camp we usually go the propane route and believe me our water is very HOT.
CharlieM
Posted: 12 Mar 2016 at 3:14pm |
Most warm hot water problems are due to the water heater bypass valves being set incorrectly. New Pods usually come set that way for some reason. Check that the two outer valves are open (handles parallel to the pipes) and the middle valve is closed (perpendicular to the pipe). The WH heats to 130F which is very hot. For faster recovery the WH can run on propane and electricity simultaneously. |
