PodDude
Topic: Avoading Re-Winterization Posted: 13 Apr 2016 at 10:41am |
Morning all. I am new to RVs and we just purchased a used 178. The original owner just had it gone through and de-winterized. That's great, but I drug it home, and it looks like it's going to be hovering near 32F here for a low two nights this week (right now forecast is 32F Fri night, 33F Sat night). I would really like to avoid re-winterizing just to turn around and de-winterize again. I'm hoping these will be the last real cold nights and after that we're out of the woods. When he was showing me everything, he opened the gray water drain and water came out, and you can see water in the toilet, so there is water in the system, but the gauges all show empty. Anyways, I was thinking about plugging it in and turning the heat on say 65 or 70 overnight, would that make sure nothing freezes? I could make sure everything is fully drained. I have a little air compressor too so I could try to blow the lines out although I've never done it. Could I put a little antifreeze in the drains to help? Advice greatly appreciated!
podrunner
Posted: 13 Apr 2016 at 11:04am |
It is my understanding that a temp of 32 will not damage the system. There is enough ambient heat that was created during the day time that it would have to get much lower than 32 and stay there for a significant amount of time to freeze the systems in the pod. We camped in yellowstone a couple of years ago and the overnight low was 23 and we suffered no damage. For extra peace of mind, you might just put a small space heater in the pod and leave it on overnight.
2010 R Pod 151
2017 4runner
2006 Honda Metropolitan
Retroactive
Posted: 13 Apr 2016 at 11:11am |
What podrunner said. 32F is an actual line in the sand, so unless it's well below 32F for a long time you will not see any freezing.
PodDude
Posted: 13 Apr 2016 at 11:41am |
Great thanks! Should I try to fully drain everything anyways?
TheBum
Posted: 13 Apr 2016 at 11:51am |
Even something as simple as an incandescent lamp placed close to the water lines can help prevent freezing.
Tars Tarkas
Posted: 13 Apr 2016 at 12:56pm |
Originally posted by PodDude
Great thanks! Should I try to fully drain everything anyways? |
Not for overnight temps above 25 (more or less).
I take the kick panel off in front of the WH & sink and plug in a portable heater set as low as it will go. It only has to be 33 to be perfectly safe.
TT
FJ Cruiser
Leo B
Posted: 13 Apr 2016 at 1:41pm |
With the temps you are talking about, you should be fine.
Posted: 13 Apr 2016 at 4:04pm |
We have camped, not winterized, below that. No issue. Our city water hose froze once.. took a few minutes of sunshine to thaw it out.. we had water in the FW holding tank, so no issue there either.
