Space Heaters |
Post Reply | Page <123 |
Guests
Guest Group |
Topic: Space Heaters Posted: 01 Nov 2009 at 7:40pm |
We are also using the Sunbeam Ceramic heater ($18.00 at Walmart) (http://www.walmart.com/catalog/product.do?product_id=12338793&sourceid=1500000000000003260370&ci_src=14110944&ci_sku=12338793) and find it to be sufficiently quiet.
Guests
Guest Group |
Posted: 01 Nov 2009 at 6:56pm |
How is it on noise?
Guests
Guest Group |
Posted: 01 Nov 2009 at 6:54pm |
It's the fan that makes too much noise to the point that it is startling and wakes us up every time it comes on. We probably just need to replace it with a newer model.
yizit
podders Helping podders - pHp Joined: 25 Feb 2009 Location: Wis. Dells, WI Online Status: Offline Posts: 663 |
Posted: 01 Nov 2009 at 6:24pm |
We have used the small 1500 watt heaters for years in our pop-ups, which could not keep up with heating in very cold weather. This year we purchased the Sunbeam Ceramic heater for R-pod and it worked great. It is small and compact and takes up very little space on the floor. I believe it also has a tip over safety switch. We used it with temps getting down into the low to mid 30's and it had no problem keeping us toasty warm. Cost...less then $20.
Former owner of 2009 172 Darlene & Jim, Ewok our Lhasa Roada our 2004 Roadtrek C190Popular |
Guests
Guest Group |
Posted: 01 Nov 2009 at 6:18pm |
I meant to say keep the condensation down with the air movement.
Guests
Guest Group |
Posted: 01 Nov 2009 at 6:13pm |
Does your heat strip in your air make to much noise and is that why you want another heat source? The fan will keep the condition down.
Guests
Guest Group |
Posted: 01 Nov 2009 at 6:10pm |
We have a Lasko ceramic heater which we have used for years in our last TT.
It has become quite noisy and we are looking to replace it.
Consumer Reports gave DeLonghi SafeHeat Flat Panel Micathermic HHP 1500 a very high rating so I'll do some investigating on that.
gmandual
Senior Member Joined: 19 Jul 2009 Online Status: Offline Posts: 246 |
Posted: 01 Nov 2009 at 6:02pm |
Both lowes and home depot carry small (2000watt or less) heaters that are designed to be installed in the walls of bathrooms or used as suplemental heat. And I think that is the route I will be going on my 172.
The only thing I am trying to decide is whether or not I am going to go with one of the broan forced air unit or go with one of the wall mounted convection heater units. For me the whole purpose of going electric is to make it so its quiet and convenient. Some of the small convection wall heaters are designed to heat rooms up to 120SQ ft which should be sufficient for a pod.
Guests
Guest Group |
Posted: 01 Nov 2009 at 4:44pm |
I am very much with you on this idea. When we pay for a camp site, part of that fee pays for electricity. When Ive already paid for electric, why use my expensive LP. I had a thought a few weeks back about removing the fabric below the sofa on my 175 making a wooden facia, installing a cabinet on the right and installing this http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200325966_200325966. Thats part of my take on the subject...
Guests
Guest Group |
Posted: 01 Nov 2009 at 4:11pm |
Ive looked at alot of Electric portable space heaters online... great way to browse !! Ive found hundreds of such units. Some with remotes, some with auto functions, some that are cool to the touch (easy placement), and so on and so on ... I have found that when searching for this particular item the reveiws are worth scanning over. For us r-Pods, there is no silver bullet when it comes to a space heater. I really dont know how important this issue is with the r-Pod owners, but with winter slowly creeping in I thought it might be interesting to get some opinions on this subject.
I believe that Cindy and I are sold on the "space heater" option after our furnace wouldnt operate on a nippy night in OH. The small very inexpensive heater did us fine, and it seemed to be much quieter than the furnace. We had little control of the thermostat as our little unit had the "ball-park" approach to temp settings. And getting up from a comfy bed to adjust it seemed the only negative by-product. (which would apply to the r-Pod furnace as well). Ive read a few posts scattered amoungst the hundreds here on such an issue. I believe that its a subject worth commenting on, and the more input we get the easier it helps us to decide whats good 'for our' particular application. There are tons of options out there, I was just wondering if it might be useful to put them in one place, and get the valuable input from fellow Pod owners as to what they use, or if they use one at all. HAPPY PODing !!! |
