Leveling blocks vs Tri-leveler |
Post Reply | Page <123> |
Mountainrev
Senior Member Joined: 22 Jul 2014 Location: Eagle, Colorado Online Status: Offline Posts: 193 |
Topic: Leveling blocks vs Tri-leveler Posted: 16 May 2016 at 6:13pm |
I'll put in another plug for BAL levelers. If you typically camp on concrete or very level surfaces (e.g., RV parks), they probably aren't what you want or need. But if you often find yourself camping on very uneven, sloped sites (e.g., National Forest), the BAL is great. You can raise one axle up to 8" or so if need be. It does take a bit of elbow grease, but not too bad. And it effectively chocks your wheel on two sides, making the camper very stable.
2014 177
2008 Jeep Grand Cherokee Turbodiesel "I lift my eyes to the hills." |
TheBum
Posted: 16 May 2016 at 6:37pm |
I wonder if a battery-operated impact driver would work on the BAL's screw. I know a regular Ryobi 18V drill doesn't. I ended up using a 300 ft-lb torque wrench I had in my car when I had to crank my BAL up rather high because it gave me plenty of leverage. That cheap wrench that came with the leveler is destined for the trash heap: I couldn't keep it from flipping directions on its own. |
Mountainrev
Posted: 16 May 2016 at 7:21pm |
You do work up a bit of a sweat if you have to raise the BAL to the maximum height on a hot day. And I agree about the cheap ratchet it comes with--the lever flips too easily. But all in all, it's very do-able and the end result is well worth the effort. No guessing on how many blocks or driving back and forth and back and forth... Just raise until the wife hollers "That's good!"
2014 177
osage
Senior Member Joined: 13 Mar 2016 Online Status: Offline Posts: 146 |
Posted: 16 May 2016 at 7:31pm |
we bought a 2x8x8ft treated board cut it 18"for the tires and 12" for all the jacks cost less than $9.00 if we need it higther on one side we just move one of the boards
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 16 May 2016 at 9:27pm |
I'd like to disagree with mountainrev. We found that the BAL leveler was easiest to use on sites that were already more or less close to level. It required a LOT of effort on sites that were not close to level. Add to that the difficulty of getting the thing in place and removing it and it is an exercise in frustration. Our BAL leveler is for sale
fwunder
Posted: 16 May 2016 at 9:50pm |
I use the orange blocks and 4x4 wood chunks under stabilizers. Orange blocks are easy, 'specially if wife just picks up corner of pod and I slide 'em under wheel.
fred |
Mountainrev
Posted: 17 May 2016 at 10:05am |
If you camp on relatively level sites, then the BAL is not the way to go, IMO. Where it shines is when you have to raise one side 5" or more in order to level. You would need a lot of boards or "Lego" blocks to do that! It is a bit challenging, but I don't find it that hard. But again, if you are in a site that is very sloped or rugged, like National Forest campgrounds often are, then I believe the BAL is the best option for leveling. The BAL can be challenging to get under the tire, especially if you have the 15" tires that come with the Hood River Edition. If you drive unto a 1" or 2" board first, then it's quite easy to slide the BAL under the tire. I don't think you'll have much trouble selling yours. They're pretty popular. |
2014 177
Happy Tripping
Posted: 22 Mar 2017 at 10:22am |
"Thanks the BAL looks great but I was looking for a lower cost solution"
Several years ago a forum member described chocks made from 2X4s, a roughly 20 inch long crossbar with 10 inch lengths at each end splayed out. He said it held airplanes so why not an r-pod? I made them, they are heavy and bulky but the price is tight.
Posted: 22 Mar 2017 at 10:42am |
A picture or sketch of what you are describing or even a more thorough description would help. I am having a hard time visualizing what you are describing. One other option for leveling that is pretty easy to use is an Andersen leveler. It is in essence, a curved ramp that one simply drives onto until the wheel is lifted enough to level the trailer. It is limited to 4" of lift, but that is often sufficient. I have used the BAL leveler and agree that it is quite a workout to use it. Greasing the screw helps. It is capable of a higher lift than the Andersen leveler and has the advantage of not requiring driving onto of off of like boards or blocks. What I don't like is that the platforms that hold the tire are welded so that they do not stay flat to the tire, but tilt which distorts the tread and sidewall. That is the main reason I have not been using mine lately. Otherwise, I like that one can simply park the trailer and then level without having to guess, move, adjust, move, etc. until it is leveled. At small elevations, the distortion of the tire is not bad. For that though, the Andersen leveler is easier. |
TheBum
Posted: 22 Mar 2017 at 11:53am |
The impact wrench idea for the BAL leveler was a bad one. It severely damaged the screw. We use the Anderson leveler now and it's so much easier to deal with. I mounted a level on the front of the Pod where we can see it in the rear view mirror, which makes it very easy to determine when you're level without having to exit the TV.
