slide paranoia |
Post Reply | Page 12> |
rvshopping
Newbie Joined: 04 Feb 2016 Online Status: Offline Posts: 11 |
Topic: slide paranoia Posted: 24 May 2016 at 2:20pm |
We are camping with just the battery for two nights this weekend. I upgraded to a slightly bigger battery (group size 27). My fear is that we will run out of battery and not be able to put the slide in. Will plugging it into our car do the trick? I guess worst case scenario we drive with it open some place very close, ideally on the campground, and plug it in? Any advice?
Posted: 24 May 2016 at 3:15pm |
Carry a set of jumper cables when boondocking. In case of emergency, "jump" your battery. Jumper cables can move a lot of amps quickly.
EDIT: we did 3 days on the group 24 once. Conserve amps. |
Mountainrev
Senior Member Joined: 22 Jul 2014 Location: Eagle, Colorado Online Status: Offline Posts: 193 |
Posted: 24 May 2016 at 3:32pm |
If the issue is concern over packing up at the end of the weekend and having the slideout stuck out, all you would have to do is hitch up and connect the 7-way plug to your tow vehicle in order to slide it in. If you're done camping, you wouldn't have to wait for your battery to recharge with jumper cables. Plug and play, and you're on your way. (That's got a ring to it, doesn't it?)
2014 177
2008 Jeep Grand Cherokee Turbodiesel "I lift my eyes to the hills." |
Posted: 24 May 2016 at 5:57pm |
Not knowing what tow vehicle they have, we don't know if it's charging the pod or not.. We know the jumper cables will send enough current. |
Leo B
Posted: 24 May 2016 at 6:59pm |
Good point.
Podster
Posted: 24 May 2016 at 10:56pm |
You don't mention what type of slide you have. Schwintek or the Lippert over the floor type. You may or may not be able overcome a low battery / slide problem by plugging into your tow vehicle. If it is set-up properly, you should be able to plug in, start your TV, and have the power you need to draw the slide in. However, keep in mind the minute you do plug in with a dead camper battery, your TV alternator is going to get slammed right away with the charge draw by the POD dead battery.
Cliff & Raelynn
sailor323
Senior Member Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 25 May 2016 at 5:12am |
There is always the option of operating the slide out manually.
rvshopping
Posted: 25 May 2016 at 11:13am |
I'm not sure which type of slide we have. Our pod is a 2017 176T. Our TV is a nissan pathfinder and we have the 7 way plug. We'll bring jumper cables in case plugging it in to the car isn't working for some reason. I guess in the first year there is lots of "finding out" this stuff--I'm trying to prevent finding out the hard way :o)
Posted: 25 May 2016 at 2:26pm |
Nothing wrong with that.. it's how you handle the finding out the hard way that matters.. I believe all 2017's have a Scwintek slide. Manually operating that slide isn't easy, well, neither is the other style, but the S-tek is worse. Video link.. |
rvshopping
Posted: 25 May 2016 at 2:30pm |
Great! I will watch that, too. Then we'll have nothing to worry about, maybe. Except for the 90 degree temps and no power other than the battery :o)
