Battery drain while In storge |
Post Reply | Page 12> |
AZ Hiker
Newbie Joined: 04 Sep 2016 Location: Arizona Online Status: Offline Posts: 7 |
Topic: Battery drain while In storge Posted: 28 Sep 2016 at 10:47pm |
Thanks a ton for all of the insight! It really helps!
R Pod 177
2011 Jeep Grand Cherokee Overland 1 Awesome Therapy Dog |
Posted: 27 Sep 2016 at 5:34pm |
Glad to be the better battery batterer!
Thanks Mick, here to help.
GlibGuy
Groupie Joined: 14 Apr 2015 Location: Virginia Online Status: Offline Posts: 65 |
Posted: 26 Sep 2016 at 9:19pm |
I certainly "hang" on everything that Doug says and have learned much from this forum since I acquired my 178 last year. My situation on using the trickle charger is that I keep my Pod in a storage warehouse (with no electric service) and it's more trouble for me to pull it home every 30 days as opposed to just bringing the battery, etc.
I'm glad to find out that I won't have to unhook and tot the battery if my next excursion is within 30 days (which is the case April through October). |
MICK
CharlieM
Posted: 26 Sep 2016 at 6:06pm |
What Doug said. Refined by the master battery batterer.
Posted: 26 Sep 2016 at 5:19pm |
I wouldn't recommend option 2, it will discharge too deeply between recharges.
If you do option 3 you need to be sure the trickle charge has enough output to cover what the LP detector and fridge will use each day. Easy way around that is to disconnect the battery from the pod but use the trickle charger. For options 4 and 6, recharge every 30 days in the warmer months, or every 60 days in the middle of winter - if you leave the batter outside in the cold (which will extend its life). We've had discussions here in the past and the consensus is you save little $ by using a trickle charger vs. the converter (and none at all if you use the converter to charge overnight every 30 days). |
CharlieM
Posted: 26 Sep 2016 at 3:38pm |
If you do not disconnect the battery it will be discharged by the propane detector in two weeks so your options are:
Your choice. Some are more convenient than others. |
GlibGuy
Posted: 26 Sep 2016 at 7:19am |
I remove my battery and put it on a trickle charger in my garage. Is this OK or would it be better to hook up every 30 days overnight?
MICK
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3220 |
Posted: 25 Sep 2016 at 6:46pm |
Our deep cycle group 24's are into their 6th year. They are either left in the pod, unhooked, or taken out and left in our unheated garage in northern Michigan. I will give them a charge in November with a trickle charger (2 amps) for 1 -2 days each and then copy this process again in April. The first year I kept them in the basement of our house but Furpod told me that they would only discharge faster being in a heated environment, that the batteries would be better off in a colder area, so that is the advice I have followed and the batteries are still working well for us.
Leo B
Posted: 25 Sep 2016 at 3:56pm |
We take our battery out each winter and recharge it a few times during the winter.
AZ Hiker
Posted: 25 Sep 2016 at 2:49pm |
Is it best to disconnect the battery and take it out while the Pod is in storage? I was thinking that it may be best to bring it home and connect to a trickle charger. Thoughts?
R Pod 177
