  New Posts New Posts RSS Feed: fridge temp
Topic Closedfridge temp
osage View Drop Down
Direct Link To This Post Topic: fridge temp
    Posted: 14 Jun 2016 at 6:34pm
95 in the shade here in eastern Kansas today Fridge set on 5 temp in fridge is running at 50.
fridge coil fans not running is there any way to check the cooling coil thermal switch.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 14 Jun 2016 at 9:43pm
What kind of power is the fridge on?  Needs to be shore power or propane.
TT
FJ Cruiser
Direct Link To This Post Posted: 15 Jun 2016 at 6:19pm
fridge is on 110 volts
CharlieM View Drop Down
Direct Link To This Post Posted: 15 Jun 2016 at 6:35pm
IIRC my RPOD fridge would only maintain 40 degrees F below outside ambient. Looks like you're 5 degrees to the good.
Direct Link To This Post Posted: 15 Jun 2016 at 7:27pm
+1 I agree
Direct Link To This Post Posted: 15 Jun 2016 at 10:13pm
but shouldn't the cooling fans come on
JandL View Drop Down
Direct Link To This Post Posted: 16 Jun 2016 at 12:04am
Here is a schematic of the Dometric RM-8501 showing the 2 fans. They are controlled by a thermal switch mounted on the condenser coil.
sch_rm_8501.pdf
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Direct Link To This Post Posted: 18 Jun 2016 at 9:49pm
Mine stayed in the upper 30's even in hot temps.  Same for my current fridge.
Direct Link To This Post Posted: 19 Jun 2016 at 9:33am
got the fridge to cool ok now had to move the thermal switch to the right hand side of the cooling coils now the fans come on  cools the the mid 30 to40 degree area  was 96 here friday
johnmaci View Drop Down
Direct Link To This Post Posted: 19 Jun 2016 at 10:36am
Was this accessible from the outside or did you have to pull out the fridge? Any before/after pictures?
