  New Posts New Posts RSS Feed: Dometic Fridge Works on DC & Gas not AC
Topic ClosedDometic Fridge Works on DC & Gas not AC - Event Date: 20 Jun 2016
Tim View Drop Down
Direct Link To This Post Calendar Event: Dometic Fridge Works on DC & Gas not AC
    Posted: 20 Jun 2016 at 1:06pm
Any idea why my Dometic fridge beeps and will not cool while plugged in to AC? It works fine running off the battery and LP. Thanks!
JandL View Drop Down
Direct Link To This Post Posted: 20 Jun 2016 at 2:22pm
You can pull off the lower vent cover and see if its plugged into the receptacle mounted to the wall. If it is you can unplug it and test the outlet with a voltage tester
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Direct Link To This Post Posted: 20 Jun 2016 at 3:01pm
Also, check the breaker in the power panel.
Tim View Drop Down
Direct Link To This Post Posted: 21 Jun 2016 at 7:56pm
Thanks! I pulled the panel off and found no power to the plug. Checked the breakers and fuses, all OK. As I sat wondering what else it could be, I checked GFI....... And that was it!
Thanks so much for pointing me in the right directionSmile
Direct Link To This Post Posted: 21 Jun 2016 at 8:36pm
Glad you found it! Those GFI things can be a pain, even though they are there to protect us.
Lksimons View Drop Down
Direct Link To This Post Posted: 21 Apr 2017 at 5:05pm
Thank you!!!  I had the same problem Smile
mcarter View Drop Down
Direct Link To This Post Posted: 21 Apr 2017 at 5:47pm
+1, sure it's not cooling, I think the alarm could be it thinks the door is not closed. There has been issues with the doorswitches in Dometics. I seem to recall a post on that from a time back. Google your issue. Condensation in the switch.
Direct Link To This Post Posted: 21 Apr 2017 at 6:33pm
Cool, literally:)
