  New Posts New Posts RSS Feed: Battery Boiling and sulfated
Topic ClosedBattery Boiling and sulfated - Event Date: 24 Jun 2016
chfgraegl View Drop Down
Direct Link To This Post Calendar Event: Battery Boiling and sulfated
    Posted: 24 Jun 2016 at 11:12am
Can I get some advice please?
On a month long road trip and we have had shore electrical connection at every place we've been .
Yesterday we noticed a rotten egg smell and the battery is hot and acid boiling and some cells dry
I added water and this morning the water was boiling. I am wondering if the inverter is overcharging the battery , it does seem to be humming all night long , one time I disconnected the power cable to reset it and it quieted down.
My rig is a 2014 R177 . Battery will be 3 this October.
Headed out of Kamloops now but will check for responses in a few hours
Thank you
TheBum View Drop Down
Direct Link To This Post Posted: 24 Jun 2016 at 1:36pm
Do you have a voltmeter to check it? It's possible a couple of the plates shorted together, which would cause more current to pass through during charging. It may just be time to replace the battery. A run of the mill battery usually has no more than an 18 month warranty.
john in idaho View Drop Down
Direct Link To This Post Posted: 24 Jun 2016 at 1:59pm
After it has set, off the charger, check the voltage.  a full charge will be in the neighborhood of 12.6v.  Your local auto parts store can do  a load test.  I suspect you need a new battery -- make sure it is a pure deep cycle , not a combo starting battery.
WillThrill View Drop Down
Direct Link To This Post Posted: 24 Jun 2016 at 9:03pm
I agree with the other posts.  It sounds like your battery has shorted out internally, and there's nothing you can do to fix that; you'll have to replace the battery.  It's possible that your converter/charger (not inverter) is overcharging your batteries, but I've never heard of a Pod converter doing that before.  When you get a new battery, keep a close eye on it for a few days.  The voltage should read about 13.6 once the battery is fully charged.  If it's much higher than that, your converter is probably malfunctioning.
2014 Hood River 177
2005 GMC Envoy XL
Direct Link To This Post Posted: 24 Jun 2016 at 10:15pm
So I went to Camping World and they were helpful, they first wanted me to put the Pod in the shop but I couldn't do that . So I knew the battery was sulfated / shorted. The customer person said that tap water can cause battery problems and before we left I topped off the cells with tap water. I think I created my own problems. So I replaced the battery and will keep monitoring it. Good to hear the converters are not problematic. Sure have learned a lot about RV'ing and Podding.
Thank you for all of the input.   Thank you all 👏👏
Direct Link To This Post Posted: 25 Jun 2016 at 10:33am
Glad to hear you found the source of the problem and got it fixed.
Yes, be sure to only refill batteries with distilled water.  When you do refill them, which shouldn't be necessary more often than every 3-6 months, just refill them to the bottom of the little tabs that stick down in toward the acid.  Be sure to not overfill them and wear eye protection when you do it.  Wear old clothes to as if you get the tiniest of drops on your clothes, the acid will burn a hole right through them.
2014 Hood River 177
2005 GMC Envoy XL
Direct Link To This Post Posted: 25 Jun 2016 at 1:48pm
Good tip on the eye protection , staring at a sulfated battery I'm lucky it didn't blow up in my face
Thank you !!!
