Well, I did it. |
Post Reply | Page <1 23456> |
MIK
Groupie Joined: 09 Jul 2017 Location: MA Online Status: Offline Posts: 42 |
Topic: Well, I did it. Posted: 20 Oct 2018 at 9:28pm |
Hi voisj, do you have the parts list you used for this project?
2018 R-Pod 180
marwayne
Posted: 26 Nov 2017 at 7:09pm |
Well you did it. congrats
voisj
Senior Member Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 26 Nov 2017 at 11:52am |
Marwayne,
Thanks for the info! I finally put it all together and it works very well. I used an 8 x 8 heater core and a 3 speed 8" computer fan that blows the air from the back side. I hooked a switch up that allows me to use either the new exchanger/fan or the regular furnace on the original thermostat. It's just temped in, (not pretty yet), until I can test it for real, It's been 80 degrees the last 5 days and 60 at night, not the best for testing. Thanks again, John |
marwayne
Posted: 10 Nov 2017 at 11:46am |
My heater core is about 8" x !4", I have a fan on either side. The air duct is under the heater core, the air pressures meet in the middle under the heater core being pushed up and than out. I also tried a heater core like yours, however it needed a powerful fan to push the air through the tiny openings of the heater core. That is why I built my own, the fins are far enough apart for the free flow of air being pushed by the fans. I just wired it up direct , no relay switch.
voisj
Posted: 10 Nov 2017 at 8:56am |
Marwayne,
Thanks for the pictures and help. This should be fun and it's such a great idea! Your heater core looks like 12" x 8" ? I found this 12 x 8 on ebay for $36 and it's on it's way, and I Have the other parts already. Still noodling out how to power the pump and fans with a thermostat, does the thermostat send good 12v to the pump and fans or did you use a relay? Thanks again, John
Posted: 09 Nov 2017 at 7:51pm |
Fantastic work Marwayne! Very much tempted to copy your masterpiece.
marwayne
Posted: 09 Nov 2017 at 6:22pm |
voisj
Posted: 09 Nov 2017 at 11:05am |
Marwayne,
love this idea! Nice work. I'm pulling together parts for the hot water heat exchanger, What size exchanger did you use? and any update on long term use and feasibility? Thanks, John
voisj
Posted: 14 Sep 2017 at 10:57am |
+1
Posted: 14 Sep 2017 at 10:52am |
I think it is time to revisit this. How has it worked out so far in actual use?
What did you use for your heater core? I think it is time to consider building one of these. |
