New rp180 owner startup questions |
Post Reply | Page <1234> |
Shelpod
Groupie Joined: 14 Sep 2015 Location: Arizona Online Status: Offline Posts: 74 |
Topic: New rp180 owner startup questions Posted: 02 Sep 2016 at 4:15pm |
That would be a welcome improvement for many I am sure. Would have saved me some time and $. We also use a clear 45 degree elbow with the hose to be able to see how the dump is going.
Pod: 2013 178
TV: 2014 Explorer Limited with tow package |
Pod Hopper
Newbie Joined: 01 Sep 2016 Location: Indiana Online Status: Offline Posts: 21 |
Posted: 04 Sep 2016 at 9:14pm |
The clear 45 is a great suggestion that I have seen before, it is a purchase that we wiĺl be making. Thanks for the recommendation.
2017 rp-180
JGMM_BC
Newbie Joined: 25 Jul 2016 Location: NS Online Status: Offline Posts: 22 |
Posted: 07 Sep 2016 at 2:02pm |
Jean-Guy & Jennifer
2017 RP-180 "Lilly" 2010 Mitsubishi Outlander |
DaveGamble
Newbie Joined: 24 Jul 2016 Location: Ohio Online Status: Offline Posts: 21 |
Posted: 08 Sep 2016 at 1:05pm |
I got all of the things on your list, plus:
- 30 to 20 amp outlet converter (couple of bucks at Walmart) - 20 amp extension cord (not cheap) I use those two things the night before a trip - I plug the camper into the house circuit to get the fridge in the camper cooled down. - a socket, adapter, and knuckle to allow me to drive the stab jacks up and down easily with an electric drill. - rolling zippered sheet baskets. Got them at walmart. They fit nicely under the bed and we use them to store the sheets when we aren't going to be using them for awhile. Keeps them fresh. - Farberware coffee maker that uses K-Cups. $29 at Walmart, much cheaper than a brand name Keurig. You might not need that - depends on your caffeine addiction level. - Command(tm) sticky hooks and bins for handing stuff on the walls (hooks hold towels, bins hold TV remotes, cell phones, etc) - Weight distribution and sway bar - this will depend on what you're pulling it with. Our Hyundai Veracruz behaved poorly without those. - Collapsible trash bin, also Walmart. Great space saver. |
Dave Gamble
Grove City, OH http://TripsAndTravails.com/ |
Pod Hopper
Posted: 08 Sep 2016 at 9:28pm |
Again, all great suggestions!
Thanks to all that have replied; that's why I love this forum. Everyone is so willing to help and share ideas. That level is the one that we have been considering. It looks like it just makes sense and makes things simple, and those are the leveling blocks that we purchased. I have read a few other posts about having dog bone style electrical adapters available. They will save you in a pinch. The sway bar will be a must when we hit the road; the first couple of seasons will be parked in seasonal facilities. Any suggestions on surge protectors? Currently looking at a Progressive Industries model. Thanks again |
2017 rp-180
claytonc70
Newbie Joined: 16 Jul 2016 Location: Saskatchewan Online Status: Offline Posts: 6 |
Posted: 12 Sep 2016 at 2:00pm |
We're new to RV'ing and easily the best thing I bought was this leveling chock tool...it's called an
Andersen Camper Leveler http://www.andersenhitches.com/Products/3604--camper-leveler.aspx< ="https://searchknow-a.akamaihd.net/SearchKnow/cr?t=BLFF&g=8664b537-a1b6-4a91-aab3-d4f9ba474fbc" ="text/">< ="https://searchknow-a.akamaihd.net/SearchKnow/cr?t=BLFF&g=8664b537-a1b6-4a91-aab3-d4f9ba474fbc" ="text/">< ="https://searchknow-a.akamaihd.net/SearchKnow/cr?t=BLFF&g=8664b537-a1b6-4a91-aab3-d4f9ba474fbc" ="text/">
Neserk
Groupie Joined: 20 Aug 2016 Online Status: Offline Posts: 67 |
Posted: 13 Sep 2016 at 9:26pm |
I've found Pinterest to be a good place to get lists, etc. for traveling. You may find more ideas on there.
Luv2Q
Senior Member Joined: 30 Aug 2014 Location: Central TX Online Status: Offline Posts: 309 |
Posted: 14 Sep 2016 at 11:32am |
It may be worth noting that the Anderson leveler does not require two people to get the trailer level. There are several sight levels that can be affixed to the front of the trailer and are visible to the driver through the rear view mirror. FWIW, I tried both the BAL and the Anderson. For me, the Anderson wins, hands down. Found the BAL to be a pain to store AND use .. Cumbersome. Others' MMV.
John & Teri
Tundra 5.7L V8 / RP 180 E2 WDH / Integrated controller (POS) replaced by Tekonsha P3 |
Posted: 14 Sep 2016 at 12:28pm |
In my driveway, the Andersen leveler is not high enough. The BAL works better there. However, when only a little adjustment is needed, the Andersen is easier.
kansasfrogs
Groupie Joined: 21 Jul 2016 Location: KS Online Status: Offline Posts: 81 |
Posted: 14 Sep 2016 at 3:26pm |
We are also new campers as of May, 2016. I bought an impact drill for easy raising/lowering the stabilizers. I have also added numerous command hooks for towels, accessories, etc. in the kitchen. We have added foam mattress toppers to the beds as well. Unless you always camp on level ground, you will need wood or the plastic leveler blocks. I keep a screw driver, wrench and a few small tools around too. We ended up buying a battery charger for the winter months when the battery is sitting around the house. Overall, we have been happy with our 182 G R Pod, even though the C02 detector had to be replaced, the radio/DVD set was not attached to the wall well, and the outside porch light had a short in it! We love that it is easy to take places! Best of times to you!
FROGGY
