  New Posts New Posts RSS Feed: Roof mount solar and Warrantee ??
Topic ClosedRoof mount solar and Warrantee ??
SteveF View Drop Down
Direct Link To This Post Topic: Roof mount solar and Warrantee ??
    Posted: 09 Sep 2016 at 10:45am
Hello. Does anyone know if there are issues with a new R-Pod warrantee if solar is mounted on the roof? If holes are drilled for screws or to run the wiring, does it void the warrantee? Thanks in advance for any information!
Steve, Vicki and Bodie
kymooses View Drop Down
Direct Link To This Post Posted: 09 Sep 2016 at 4:41pm
If you had any type of water intrusion, or issue on the roof or anything related to that addition it would void the warranty.
So yes, when you drill holes, cut holes, or add/change things that are not factory you will void the warranty on those parts.  The warranty covering say the shower leaking or a window falling out wouldn't be an issue but anything that could be related to that mod would be void.
Direct Link To This Post Posted: 09 Sep 2016 at 5:14pm
Thanks, that is reasonable.
ChinookPod View Drop Down
Direct Link To This Post Posted: 10 Sep 2016 at 10:16pm
We purchased a Go Power solar flexible panel and it is attached with "3M" tape I'm told.  No holes.  The wires were run down the former TV antenna hole.  (We don't have a television and the antenna always rattled anyway...)
2014 RP171 HRE
2010 F150
Direct Link To This Post Posted: 11 Sep 2016 at 1:43pm
Good idea. I did see somewhere else, that panels are mounted with 3m VHB tape. Then if you are able to run the cables through a vent pipe or the tv antenna, as you mentioned, no new holes would be needed in the roof. Too bad there isn't a plug on the roof for solar like on the side.
