Fridge not cooling on propane - fixed! |
Post Reply | Page 123> |
Craneman
Senior Member Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
Topic: Fridge not cooling on propane - fixed! Posted: 20 Sep 2016 at 9:55pm |
Posted: 20 Sep 2016 at 7:51pm |
100% imported with insane prices for parts compared to most other fridges.
fwunder
Posted: 20 Sep 2016 at 12:14pm |
Ahhh, thanks Stephen.
It's a Dometic RM8501 Best parts diagram I could find: Best burner image I could find: I'm glad I was able to fix. Looks like parts might be hard to come by unless they may be interchangeable with newer model. fred |
Posted: 20 Sep 2016 at 11:37am |
Remove the crisper drawer in the bottom. The label should then be visible.
fwunder
Posted: 20 Sep 2016 at 9:04am |
I can't seem to find a model number of my fridge. I imagine they did use different models from year to year, pod to pod.
Posted: 19 Sep 2016 at 8:48pm |
Looks like a stove's burner instead of a single flame.
Posted: 18 Sep 2016 at 9:42pm |
I did get a couple of pictures. The burner on mine is quite different from the one pictured above.
fwunder
Posted: 16 Sep 2016 at 8:44pm |
You're right. I didn't. I filled a Dixie cup full of alcohol and dipped the burner assembly, supply tube attached, into it. That way, the jet wasn't exposed. I have a bunch of syringes I keep around for caulking (much easier than caulk gun) that I used to inject alcohol through tubing and jet. Like I said before, a blast of air and vacuum may have fixed it. fred
Posted: 16 Sep 2016 at 8:28pm |
Looking at that last picture, if you unscrew the burner assembly from the hex nut on the end of the tube the orifice is in there. Doesn't look like you took that off?
Posted: 15 Sep 2016 at 9:46pm |
Interesting! The burner on your refrigerator looks different than the one on my refrigerator. Now I will have to get pictures to post.
